CME to CUCM as a H323 GW
stowellp
Hi All,
I have a small remote site that has a 2851 runnning CME 7 and wish to get the phones to register to a CUCM (v7.1)in London. Currently the PSTN connections are 5 x FXO ports that have PLAR OPX configured to reception x100. The CME will be registered as an H323 gateway as we are using analogue ports.
My question is how do I configure the FXO ports and dial peers to ring the reception dn once it is configured on CUCM? Can I use PLAR OPX and create a dial-peer with that pattern pointing to CUCM, or should I use translation patterns to amend the called number on the ports?
Any help and or example configs for the H323 GW would be appreciated.
Phil
paolo bevilacqua
Just plar to a number the CUCM can handle, and of course have DP covering it.
paolo bevilacqua
Just tested using PLAR and it worked that's great thanks, it's
much appreciated!
Cheers,
Phil
