CME Transfer Call system blind
Hi!
I would like to know if it's possible to  make transfer after calling outside without waiting an anser from the other side
receptioneist--> call a 9T number {transfer without waiting to anser}-->local number
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
fxo hook-flash
max-ephones 200
max-dn 600
ip source-address 10.1.1.1 port 2000
calling-number local
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
cnf-file location flash:
load 7911 SCCP11.9-2-1S
load 7931 SCCP31.9-2-1S
load 7945 SCCP45.9-2-1S
load 7975 SCCP75.9-2-1S
time-zone 28
time-format 24
keepalive 30 auxiliary 4
bulk-speed-dial list 2 flash:code.txt
bulk-speed-dial prefix *
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh "flash:/media/music-on-hold.au"
multicast moh 239.10.16.16 port 2000
web admin system name ****** password *******
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern .T
transfer-pattern 0T
transfer-pattern T
transfer-pattern 8...
Sh Ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 16-Nov-11 00:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M8, RELEASE SOFTWARE (fc1)
CLINIQUE uptime is 1 week, 3 days, 21 hours, 55 minutes
System restarted at 12:44:48 UTC Fri Nov 2 2012
System image file is "flash:c3900-universalk9-mz.SPA.152-2.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 995328K/53248K bytes of memory.
Processor board ID FCZ152620CW
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE100/K9       *****************
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
Best regards,
6 Replies 6
Ayodeji Okanlawon
Yes that is possible. Have you tried it?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
i trie it and didn't work
can you help to resolve it
So what happens when you tried it? Did the call disconnect or do you get a busy tone?
When you wait for the call to connect before transferring does it work?
the transfer button apear after the call ansered
if the call connected the transfer work fin. but i want to transfert the call before te call is connected
Borhen,
Ok I uderstand what th problem is. After looking at it more, I can confirm that this is not possible..
The table below shows the call state and the soft keys that are available. So the transfer key is not available until the call is connected. So sorry you cant do this
Call State
Available Softkeys
Idle
Redial, CFwdAll, DND, PickUp, GPickUp, Newcall, Login
Seized
Redial, CFwdAll, PickUp, GPickUp, EndCall
Alerting
Acct, EndCall, CallBack
Connected
Acct, Confrn, Hold, Trnsfr, Endcall, Flash, Park
