No, I dont't have it. Problem is with ephone 10
Config:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.06.09 08:21:52 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 28668 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router02_CUCME
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 2147483
enable secret 5 $1$IFQB$DLVI5F99JdgSd0KlH05wn1
--More-- aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network local_list local
aaa session-id common
clock timezone Warsaw 1
dot11 syslog
no ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool phone
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
option 150 ip 10.10.10.1
dns-server 10.0.0.18
--More-- !
no ip bootp server
ip domain name ofek.pl
ip host switch1 10.0.0.250
ip host AP01 10.0.0.240
ip host AP02 10.0.0.241
ip name-server 10.0.0.18
ip inspect tcp idle-time 1800
ip inspect name SDM_LOW appfw SDM_LOW
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW router
--More-- ip inspect name Fundacja tcp timeout 3600
ip inspect name Fundacja udp timeout 3600
ip inspect name Fundacja dns timeout 3600
ip inspect name Fundacja ftp timeout 3600
ip inspect name Ofek-Gosc tcp
ip inspect name Ofek-Gosc udp
ip inspect name tunnel0 tcp
ip inspect name tunnel0 udp
login block-for 240 attempts 6 within 60
login delay 3
login quiet-mode access-class quiet-mode
login on-failure
login on-success
no ipv6 cef
appfw policy-name SDM_LOW
application http
port-misuse p2p action reset alarm
stcapp ccm-group 1
--More-- !
stcapp feature access-code
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
registrar server expires max 1200 min 300
localhost dns:sip.inea.com.pl
--More-- !
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 100
request INVITE sip-header From modify "(<.*:)(.*@)" "<sip:Szamarzewskiego_82_1293@"
request CANCEL sip-header From modify "(<.*:)(.*@)" "<sip:Szamarzewskiego_82_1293@"
--More-- !
voice iec syslog
voice translation-rule 3
rule 1 /^4\(..$\)/ /6184604\1/
rule 2 /510/ /618430275/
rule 3 /516/ /618430276/
rule 4 /506/ /618460490/
rule 5 /507/ /618460490/
rule 6 /508/ /618460490/
rule 7 /511/ /618433151/
rule 8 /^7\(..$\)/ /618460485/
rule 9 /^6\(..$\)/ /6122286\1/
voice translation-rule 4
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 5
rule 1 /618460485/ /700/
rule 2 /612228601/ /601/
--More-- voice translation-profile FROMSIPINEA
translate called 5
voice translation-profile TOSIPINEA
translate calling 3
translate called 4
voice-card 0
crypto pki trustpoint TP-self-signed-2534025937
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2534025937
revocation-check none
rsakeypair TP-self-signed-2534025937
crypto pki certificate chain TP-self-signed-2534025937
certificate self-signed 01
3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353334 30323539 3337301E 170D3135 30313039 31343232
--More-- 32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35333430
32353933 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E6F5 50785560 AE9BCE70 07C438D7 6D98943A F96D074F 590970FE 34DBD082
F175A2A1 812BC54F 5682A682 FFC637ED 6FE94B79 164FDD00 0F01D79E E612A9DB
2450D8F0 E1638221 8EE5E508 ADD95C56 CF9E26D0 36484E2F 5B58DA6D 57EA0435
BEED291D AE5F982D B029F95A 036ECECD 8B834751 3DA5C214 99CB50C4 2278650F
91730203 010001A3 76307430 0F060355 1D130101 FF040530 030101FF 30210603
551D1104 1A301882 16726F75 74657230 325F4355 434D452E 6F66656B 2E706C30
1F060355 1D230418 30168014 C3CAA201 DBE2C174 147CA863 61A3C1C9 B63321DB
301D0603 551D0E04 160414C3 CAA201DB E2C17414 7CA86361 A3C1C9B6 3321DB30
0D06092A 864886F7 0D010104 05000381 8100DD4E 58B93CB3 D3792A88 C349A19B
82655EF0 EA914305 50E0C1C5 EE0673BD 6CE15A28 2C11D7FF 18602D7B F8A3AB0B
F10E4615 68F6086E A25BCFE8 B5F5603F 0EDF5DDA 78E76902 81C1E0BB DDFE084B
493D3E93 793367C9 84B66D43 F26C4061 4518F405 58B99C23 46500DAE 9E2D7EF7
6DAE86EE EC3BE8E3 6C543C97 003D8563 2852
quit
username admin privilege 15 secret 5 $1$Z9wm$8xxtEewgq3N9dlzFrHxQp0
username cue privilege 15 secret 5 $1$y71t$VfVSOT.WJtXopenAAOn8p0
archive
log config
--More-- hidekeys
path ftp://77.65.5.230/backup/ofek/router02/
write-memory
ip tcp window-size 65535
ip tcp synwait-time 10
ip ftp source-interface FastEthernet0/0.1
ip ftp username backup
ip ftp password 7 00251710265A08575F
ip ssh authentication-retries 2
ip ssh version 2
class-map match-all control-plane-cmap
match access-group name control-plane-acl
policy-map control_plane_pmap
class control-plane-cmap
police 40000 conform-action transmit exceed-action drop violate-action drop
--More-- !
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.6 255.255.255.252
ip nat inside
ip virtual-reassembly
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat inside
duplex auto
speed auto
--More-- no mop enabled
encapsulation dot1Q 1 native
ip address 10.0.0.2 255.255.255.0
no ip redirects
no ip unreachables
ip accounting precedence input
ip nat inside
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 10.10.10.1 255.255.255.0
no ip unreachables
ip nat inside
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.5 255.255.255.252
--More-- service-module ip default-gateway 10.1.10.6
interface FastEthernet0/1
description wan
ip address 192.168.239.58 255.255.255.248
ip access-group wan2lan in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 10.1.10.5 255.255.255.255 Service-Engine0/0
ip route 62.21.102.138 255.255.255.255 192.168.239.57
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
--More-- ip http path flash:
ip flow-top-talkers
top 20
sort-by bytes
ip access-list extended NAT
permit ip 192.168.0.0 0.0.0.255 any
permit ip 10.0.0.0 0.0.0.255 any
permit ip 10.10.10.0 0.0.0.255 any
ip access-list extended control-plane-acl
permit tcp 10.0.0.0 0.0.0.255 any eq 22
permit tcp 192.168.55.0 0.0.0.255 any eq 22
deny tcp any any eq 22
ip access-list extended den
deny ip any any log
ip access-list extended deny
deny ip any any log
ip access-list extended quiet-mode
permit ip host 77.65.5.226 any log
permit ip 10.0.0.0 0.0.0.255 any log
ip access-list extended wan2lan
--More-- permit udp host 62.21.99.246 any log
permit udp host 62.21.102.138 host 192.168.239.58 log
deny ip any any log
logging trap debugging
logging source-interface FastEthernet0/0.1
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.0.255
snmp-server community public RO
tftp-server flash:cnu45.8-4-1-23.sbn
tftp-server flash:dsp45.8-4-1-23.sbn
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:apps45.8-4-1-23.sbn
--More-- tftp-server flash:jar45sccp.8-4-1-23.sbn
tftp-server flash:cvm45sccp.8-4-1-23.sbn
tftp-server flash:SCCP45.8-4-2S.loads
tftp-server flash:B016-1-0-3.SBN
tftp-server flash:Desktops/320x212x12/OFEK2.png
tftp-server flash:Desktops/320x212x12/OFEK.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Sax1.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:RingList.xml
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouTheref.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Classic1.raw
--More-- tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax2.raw
tftp-server flash:Chime.raw
tftp-server flash:Vibe.raw
--More-- tftp-server flash:CiscoIPPhoneMenu.xml
tftp-server flash:SEPF0DEF11F8C9B.cnf.xml
tftp-server flash:APPS-1.2.1.SBN
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:GUI-1.2.1.SBN
tftp-server flash:SYS-1.2.1.SBN
tftp-server flash:TNUX-1.2.1.SBN
tftp-server flash:TNUXR-1.2.1.SBN
tftp-server flash:WLAN-1.2.1.SBN
tftp-server flash:APPS-1.4.1SR1.SBN
tftp-server flash:CP7921G-1.4.1SR1.LOADS
tftp-server flash:GUI-1.4.1SR1.SBN
tftp-server flash:SYS-1.4.1SR1.SBN
tftp-server flash:TNUX-1.4.1SR1.SBN
tftp-server flash:WLAN-1.4.1SR1.SBN
radius-server host 10.0.0.18 auth-port 1645 acct-port 1646 key 7 11061F001C1D0D090F
control-plane
voice-port 0/2/0
--More-- compand-type a-law
cptone PL
timeouts ringing infinity
description Domofon
station-id name Domofon
caller-id enable
voice-port 0/2/1
compand-type a-law
cptone PL
description FAX 601
station-id name FAX 601
caller-id enable
ccm-manager fax protocol cisco
mgcp fax t38 ecm
sccp local Loopback0
sccp ccm 10.10.10.1 identifier 1 version 7.0
sccp ccm group 1
--More-- associate ccm 1 priority 1
dial-peer voice 2001 voip
description Voice mail
destination-pattern 666
session protocol sipv2
session target ipv4:10.1.10.5
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2000 voip
destination-pattern 1[0-9].
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2002 voip
destination-pattern 618460480
--More-- dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2003 voip
description voice mail autoatendant
destination-pattern 667
codec g711ulaw
no vad
dial-peer voice 2004 voip
description voicemail prompt
destination-pattern 668
codec g711ulaw
no vad
dial-peer voice 10 pots
description domofon
--More-- destination-pattern 500
port 0/2/0
no sip-register
dial-peer voice 3 pots
preference 7
incoming called-number 618460...
direct-inward-dial
forward-digits 3
dial-peer voice 7 pots
direct-inward-dial
forward-digits 3
dial-peer voice 15 pots
destination-pattern 601
port 0/2/1
forward-digits 0
no sip-register
dial-peer voice 2007 voip
destination-pattern 7[0-9][0-9]
--More-- session protocol sipv2
session target ipv4:10.1.9.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2008 voip
translation-profile outgoing TOSIPINEA
max-conn 10
destination-pattern 9T
voice-class codec 1
session target dns:sip.inea.com.pl
dtmf-relay rtp-nte
dial-peer voice 2009 voip
translation-profile incoming FROMSIPINEA
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
--More-- !
dial-peer voice 2005 voip
destination-pattern 6[0-9].
session target ipv4:10.0.152.1
codec g711ulaw
no vad
dial-peer voice 2006 voip
destination-pattern 612228600
codec g711ulaw
no vad
sip-ua
credentials username z_paderewskiego_8_1391 password 7 15141D3F5C753C2E1E643C33215420073701 realm sip.inea.com.pl
authentication username z_paderewskiego_8_1391 password 7 03024D385E503646785E101425413D08327D
registrar dns:sip.inea.com.pl expires 3600
--More-- sip-server dns:sip.inea.com.pl
telephony-service
authentication credential admin AdvOfe10/@A
em logout 0:0 0:0 0:0
max-ephones 42
max-dn 60
ip source-address 10.10.10.1 port 2000
max-redirect 20
auto assign 5 to 8 type anl
auto assign 1 to 50
caller-id block code *916
calling-number initiator
service phone videoCapability 1
timeouts interdigit 5
system message Fundacja eSzkola
url services http://10.1.10.5/voiceview/common/login.do
cnf-file location flash:
load 7916-24 flash:B016-1-0-3
load 7921 CP7921G-1.4.1SR1
--More-- load 7945 term45.default
load 7965 SCCP45.8-4-2S
time-zone 23
time-format 24
date-format dd-mm-yy
live-record 473
voicemail 666
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin secret 5 $1$AFhu$5i4PwW6nUIvTL6bseSxjA0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
directory entry 1 491 name Ryszard Stefanowski
directory entry 2 481 name Alicja Czeszewska
directory entry 3 482 name Dariusz Kessel
create cnf-files version-stamp Jan 01 2002 00:00:00
--More-- !
ephone-template 1
softkeys connected LiveRcd Hold Trnsfer Park Confrn
ephone-dn 1 dual-line
number 498 secondary 618460498 no-reg both
label 498 M.Rogozinska
description Malwina Rogozinska
name Mrogozinska
call-forward all 482
call-forward busy 666
call-forward noan 666 timeout 45
huntstop channel
no huntstop
hold-alert 30 originator
ephone-dn 2 dual-line
number 481 secondary 618460481 no-reg both
label 481 A.Czeszewska
description Alicja Czeszewska
name ACzeszewska
--More-- call-forward busy 666
huntstop channel
no huntstop
ephone-dn 3 dual-line
number 482 secondary 618460482 no-reg both
label 482 M.Grzegorzewicz
description Marta Grzegorzewicz
name MGrzegorzewicz
huntstop channel
no huntstop
ephone-dn 4 dual-line
number 604 secondary 612228604 no-reg both
label 604 KWojtan
description KWojtan
name KWojtan
huntstop channel
--More-- no huntstop
ephone-dn 5 dual-line
number 629 no-reg both
label 629 MMichalska
description MMichalska
name MMichalska
huntstop channel
no huntstop
ephone-dn 6 dual-line
number 487 secondary 618460487 no-reg both
label 487 A.Kowalska
description Agnieszka Kowalska
name AKowalska
call-forward noan 666 timeout 30
huntstop channel
no huntstop
--More-- !
ephone-dn 7 dual-line
number 628
label 628 KWitkowska
description KWitkowska
name KWitkowska
huntstop channel
no huntstop
ephone-dn 8 dual-line
number 494 secondary 618460494 no-reg both
label 494 P.Gmerek
description Piotr Gmerek
name PGmerek
call-forward all 607
huntstop channel
no huntstop
ephone-dn 9 dual-line
number 493 secondary 618460493 no-reg both
--More-- label 493 L.Jurkowlaniec
description Lucyna Jurkowlaniec
name LJurkowlaniec
call-forward all 608
huntstop channel
no huntstop
ephone-dn 10 dual-line
number 492 secondary 618460492 no-reg both
label 492 L.Duda
description Leszek Duda
name LDuda
huntstop channel
no huntstop
ephone-dn 11 dual-line
number 615 secondary 612228615 no-reg both
label 615 SalaKonferencyjna-parter
--More-- description SalaKonferencyjna-parter
name SalaKonferencyjna-parter
huntstop channel
no huntstop
ephone-dn 12 dual-line
number 499 secondary 618460499 no-reg both
label 499 Fax Oddzial
description Fax Oddzial
name Fax Oddzial
call-forward all 489
huntstop channel
no huntstop
ephone-dn 14 dual-line
number 603 secondary 612228603 no-reg both
label 603 AKonieczna
description Agnieszka Konieczna
name AKonieczna
--More-- huntstop channel
no huntstop
ephone-dn 15 dual-line
number 601 secondary 612228601 no-reg both
label 601 FAX
description FAX
name FAX
no huntstop
ephone-dn 16 dual-line
number 500 no-reg both
label 500 Domofon
description Domofon
name Domofon
call-forward all 500
ephone-dn 17 dual-line
number 620 secondary 612228620 no-reg both
--More-- label 620 Paderewskiego
description Paderewskiego
name Paderewskiego
ephone-dn 18 dual-line
number 496 secondary 618460496 no-reg both
label 496 A.Ruszel
description Arleta Ruszel
name ARuszel
call-forward all 621
huntstop channel
no huntstop
ephone-dn 19
number 497 secondary 618460497 no-reg both
label 497 M.Rycharski
description Marcin Rycharski
name MRycharski
no huntstop
--More-- ephone-dn 20 dual-line
number 608 secondary 612228608 no-reg both
label 608 LJurkowlaniec
name LJurkowlaniec
huntstop channel
no huntstop
ephone-dn 21
number 591 no-reg both
label 591 R.Stefanowski
description Ryszard Stefanowski
name RStefanowski
ephone-dn 22 dual-line
number 501 no-reg both
label 501 K.Urbanek
description Karolina Urbanek
name KUrbanek
huntstop channel
ephone-dn 23 dual-line
number 600 secondary 612228600 no-reg both
label 600 AGrembowska
description AGrembowska
name AGrembowska
huntstop channel
no huntstop
ephone-dn 24 dual-line
number 483 secondary 618460483 no-reg both
label 483 J.Sypniewska
description Joanna Sypniewska
name JSypniewska
call-forward all 600
huntstop channel
no huntstop
ephone-dn 25 dual-line
--More-- number 613 secondary 612228613 no-reg both
pickup-group 2
label 613 MMordas
description Marcin Mordas
name MMordas
ephone-dn 26 dual-line
number 612 secondary 612228612 no-reg both
pickup-group 2
label 612 APytlarz
description Andrzej Pytlarz
name APytlarz
ephone-dn 27 dual-line
number 611 secondary 612228611 no-reg both
label 611 KZiolek
description Krzysztof Ziolek
--More-- name KZiolek
ephone-dn 28 dual-line
number 509 no-reg both
label 509 J.Pers
description Jacek Pers
name JPers
ephone-dn 29 dual-line
number 606 secondary 612228606 no-reg both
label 606 MBlaszczak
description MBlaszczak
name MBlaszczak
huntstop channel
no huntstop
ephone-dn 30
number 511 secondary 618433151 no-reg both
--More-- label 511 A.Mlynska
description Agnieszka Mlynska
name AMlynska
call-forward all 493
ephone-dn 31
number 605 secondary 612228605 no-reg both
label 605 PMroz
description PMroz
name PMroz
ephone-dn 32 dual-line
number 610 secondary 612228610 no-reg both
label 610 PStelmaszyk
description PStelmaszyk
name PStelmaszyk
ephone-dn 33 dual-line
--More-- number 614 secondary 612228614 no-reg both
label 614 SalaKonferencyjna-Ipietro
description SalaKonferencyjna-Ipietro
name SalaKonferencyjna-Ipietro
ephone-dn 34 dual-line
number 609 secondary 612228609 no-reg both
label 609 AKalisz
description Agnieszka Kalisz
name AKalisz
huntstop channel
no huntstop
ephone-dn 35 dual-line
number 607 secondary 612228607 no-reg both
label 607 PGmerek
description PGmerek
name PGmerek
huntstop channel
no huntstop
--More-- !
ephone-dn 46
number 471 no-reg primary
intercom 472 label "RStefanowski"
ephone-dn 47
number 472 no-reg primary
intercom 471 no-auto-answer label "MRogozinska"
ephone-dn 48
number 470 no-reg primary
name all
paging ip 239.1.1.10 port 2000
ephone-dn 50
number A800... no-reg both
mwi on
ephone-dn 51 dual-line
number 621 secondary 612228621 no-reg both
label 621 ARuszel
name ARuszel
huntstop channel
no huntstop
ephone-dn 52
number 622 secondary 612228622 no-reg both
label 622 AMusisz
description AMusisz
name AMusisz
no huntstop
ephone-dn 53
number 473 no-reg both
call-forward all 666
ephone-dn 60 dual-line
--More-- number 602 secondary 612228602 no-reg both
label 602 RStefanowski
name RStefanowski
huntstop channel
no huntstop
ephone 1
device-security-mode none
mac-address 0025.4592.DFBD
ephone-template 1
paging-dn 48
type 7965 addon 1 7916-24
button 1:23 7m60 8m14 9m4
button 10m31 11m29 12m35 13m20
button 14m34 15m51 16m27 17m26
button 18m25 19m33 20m11 21m17
button 22m32
--More-- ephone 2
description PGmerek
mac-address 0023.EB53.5D4E
ephone-template 1
max-calls-per-button 4
paging-dn 48
type 7945
button 1:35
ephone 3
description KZiolek
mac-address 0023.EB53.5EFD
ephone-template 1
username "KZiolek" password 12345
paging-dn 48
type 7945
button 1:27
--More-- !
ephone 4
description Witkowska
mac-address 0023.EB52.9B8B
type 7945
button 1:7
ephone 6
mac-address 0023.EB52.98FA
ephone-template 1
paging-dn 48
type 7945
button 1:19
ephone 7
mac-address 0023.EB52.8B92
--More-- ephone-template 1
username "ACzeszewska" password 12345
paging-dn 48
type 7945
button 1:2 2m3
ephone 8
mac-address 0023.EB52.993E
ephone-template 1
username "MMichalska"
paging-dn 48
type 7945
button 1:5
ephone 9
mac-address 0023.EB52.9A64
paging-dn 48
type 7945
button 1:29
ephone 10
mac-address 0023.EB53.5841
ephone-template 1
username "ARuszel" password 123456
speed-dial 1 9618273041 label "Andrzej Musisz"
paging-dn 48
type 7945
button 1:51
ephone 11
description LJurkowlaniec
mac-address 0023.EB53.577A
username "LJurkowlaniec" password 12345
paging-dn 48
type 7945
button 1:20
ephone 12
mac-address 0021.FE5D.6759
ephone-template 1
paging-dn 48
type 7945
button 1:10
ephone 13
mac-address 001F.5C2A.157E
ephone-template 1
paging-dn 48
--More-- type 7945
button 1:14
ephone 14
mac-address 001A.6B66.6041
ephone-template 1
paging-dn 48
type CIPC
button 1:10 3m14 4m9 5m8
button 8m1
ephone 15
description APytlarz
mac-address A088.B4E1.8740
type CIPC
button 1:26
--More-- !
ephone 16
mac-address 001F.160E.0825
ephone-template 1
paging-dn 48
type CIPC
button 1:21 2m10 3m9 4m8
button 5m14 6m2 7m5
ephone 17
mac-address 001C.2516.B2E6
ephone-template 1
paging-dn 48
type CIPC
button 1:16
--More-- !
ephone 18
mac-address 381C.1ABA.C8A5
type 7945
button 1:17
ephone 19
mac-address 0026.2DF1.075B
ephone-template 1
paging-dn 48
type CIPC
button 1:21 2m14 3m10 4m2
button 5m9 7m11 8m16
ephone 20
mac-address 8843.E132.88EA
paging-dn 48
type 7921
button 1:23
ephone 22
mac-address 0021.FE55.0F41
ephone-template 1
type 7970
button 1:21
ephone 23
mac-address 0000.0000.0001
ephone-template 1
max-calls-per-button 2
paging-dn 48
--More-- type anl
button 1:16
ephone 24
ephone 25
mac-address F0DE.F17F.1108
type CIPC
button 1:21
ephone 26
mac-address F0DE.F131.55CC
ephone-template 1
paging-dn 48
--More-- type CIPC
button 1:10
ephone 27
mac-address D0C2.82D1.059B
ephone-template 1
paging-dn 48
type 7945
button 1:3
ephone 28
description MMordas
mac-address D0C2.82D1.066B
ephone-template 1
paging-dn 48
type 7945
button 1:25
--More-- !
ephone 30
mac-address 0021.6AAA.035C
ephone-template 1
type CIPC
button 1:21
ephone 31
mac-address F0DE.F131.55ED
ephone-template 1
paging-dn 48
type CIPC
button 1:19
ephone 32
--More-- device-security-mode none
mac-address 001F.CA36.4B19
ephone-template 1
ephone 33
mac-address D0C2.82D1.704B
ephone-template 1
paging-dn 48
type 7945
button 1:34
ephone 34
mac-address D0C2.82D1.6CFF
username "MRogozinska" password 12345
paging-dn 48
type 7945
button 1:1 2:46
--More-- !
ephone 36
mac-address D0C2.82D1.721F
type 7945
button 1:26
ephone 38
ephone 41
mac-address D0C2.82D0.FCE9
ephone-template 1
paging-dn 48
--More-- type 7945
button 1:31 2:52
ephone 42
mac-address D0C2.82D0.F8BB
ephone-template 1
paging-dn 48
type 7945
button 1:19
ephone 44
mac-address 8853.2E4A.5511
type CIPC
button 1:19 3m14
--More-- ephone 45
mac-address 6886.A7C4.014D
type 7945
button 1:11
ephone 46
mac-address 7C95.F3C8.9B05
type 7945
button 1:33
ephone 47
mac-address B862.1F6C.0803
type 7945
--More-- !
ephone 48
mac-address 7C95.F3C8.9E68
type 7945
button 1:30
ephone 49
description AKonieczna
mac-address 346F.9017.B0BB
type 7945
button 1:14
ephone 50
description PMroz
mac-address CCD5.39D7.F1BC
--More-- type 7945
button 1:31
ephone 51
mac-address 885A.9202.E0DF
type 7945
button 1:32
ephone 60
description RStefanowski
mac-address 0023.EB52.9944
ephone-template 1
type 7945
button 1:60
--More-- !
ephone 61
description KWojtan
mac-address BC16.F517.9069
type 7945
button 1:4
ephone 62
ephone-hunt 2 longest-idle
pilot 490 secondary 618460490
list 613, 612, 611
timeout 10, 10, 10
no-reg both
ephone-hunt 3 longest-idle
pilot 628 secondary 612228628
--More-- list 613, 612, 611, 610
timeout 10, 10, 10, 10
no-reg both
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
scheduler allocate 20000 1000
end
