cme vs cucm vs be6k
JS
Any kind sOuL,can enlighten on the above.
I understand that cme is running on a compact router as compared to cucm running on a server whereby the full features can be utilized  as compared to cme limited and inflexibility such as the push mail.
if upgrading from cme to cucm. Will,be6k do the job?
- what type of hardware is required?
- can someone explain how is the std/enhanced/premium license work under cucm
ronpatel
Level 8
Level 8
The new CUMBE 6000 is packaged solution which has CUCM/CUC UCCX etc. inclueded in it and it will be sufficient for your deployment if you do not have 1000 + users.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
