CMR/CDR export report
Hi! I`ve generated CDR report from CUCM9 serviceability tool but there are not the whole call history as i know. Does somebody has this issue?
12 Replies 12
Jaime Valencia
You might want to elaborate on what you mean by the "whole" call history
If you mean you want to see calls from the day you installed CUCM, that will not happen, CUCM can only keep records for a maximum of 180 days.
java
if this helps, please rate
Yes, sure. By the "whole" i mean for example i`m trying to request CDR for one month deep and see only 5-10 calls to the our main inbound number. That`s unbelievable statistic even for the one day because we have dozens of calls each hour...
Please chek CDR enable flag and CDR log calls with zero duration at  system > service parameters > advanced
Thanks for your answer but cant find CDR flag, dont have "advanced" option in service parameters. How to find it?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_6_1/car/car/caranrpt.html#wp1037699
here is a step by step guide
Don`t have "advanced" button for some reason...
You would have to choose a server first......
ok, server chosen but still dont have "advanced" button
call manager service
Ok, thanks! The CDR Flag has been already enabled. But "zero duration calls" disabled. is it right?
You can mark it as enabled.
+5 Alexey. Seems that your CDR isn't enabled hence you can see any CDR records.
You need to enable it on all servers.
