Bookmark
Subscribe
1626
.cnf.xml , .cnf format files on tftp
sarahr202
Level 5
Level 5
Hi everybody
I just find this link explaining what config file is requested by cisco ip phone from tftp server during boot up.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/a02tftp.html
A quote from the link:
If a phone has an XML-compatible load, it requests a .cnf.xml format configuration file; otherwise, it requests a .cnf file.
what are those some firmware when loaded on the ip phone, will cause it to request  cnf.xml format configuration file from tftp during boot up ?
Thanks and have a great day.
Jaime Valencia
Yes, everytime the phone boots up it request the file, and if you change something in the CUCM config and it asks you to reset/reload the phone, it's because the config file changed and it needs to be reloaded with the new parameters
But that's no FW, that's a configuration file with things like directories URL, CUCM group, etc
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks Jaime.
I am sorry for the confusion.   When a phone boots up, it request files in a specific order Now what files will be requested i,e the files with xml extension or cnf extension, depends upon the FW currently executing on the phone.
My question is what are some FW which causes Phone to request XML.Cnf format during boot up?
thanks and have a great day.
