08-13-2012 11:20 AM - edited 03-16-2019 12:41 PM
Hi Everyone
I wanted to know can someone tell me how to get the conference feature to work on a 8945? I didn't know that the feature wasn't working unitl one of our end users had to put another user on the phone with the 1st person he called and it doesn't work.I came back to my desk and setup a 8945 and I tried to do a conference myself and he was right it doesn't work. I called my desk phone and then hit the confernece button on the phone and then called my cell and when I went back to hit the conference call button again to merge the calls I get a fast busy. I tried the feature on my phone which is a 7942 and the feature works fine.I would greatly appreciate any help and thanks in advance and have a great day.
Solved! Go to Solution.
08-13-2012 11:42 AM
What firmware load are you running? This phone had a ton of issues with older firmware versions, I suggest you upgrade to latest version.
Chris
08-13-2012 11:42 AM
Chris
08-14-2012 07:48 AM
Thanks alot Chris that did the trick
