Conference just in one way
Hi people.
I have a problem with a conferecen onnet calls from the headquaters to another branch.
In the headquarter we have a CUCMBE  and the remote offieces we have avaya.
A simple call works properly but when I make a conference the another person can't hear me.
I have configured the dsp farms at the router well and when I try to make a conference this is the information I have with show sccp connections.
sess_id    conn_id      stype mode     codec   sport rport ripaddr conn_id_tx
16780218   16777425     conf  sendrecv g729b   20290 23136 172.22.0.49
16780218   16777424     conf  sendrecv g729b   26410 3800  172.22.0.56
16780218   16777422     conf  sendrecv g711u   31760 20844 10.102.94.50
The 10.102.94.50 ip is a headquarter ip and I dont know why it is using g711u because I configure the regions whith g729. Can be that the problem?
this is the dspfarm conference configuration.
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 15
associate application SCCP
Thank you.
Chris Deren
Make sure you SCCP configuration is bound to a particular interface.
HTH,
Chris
12 Replies 12
Chris Deren
HTH,
Chris
Thanks for the answer.
Yes it is.
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 3 register MTP_GW_TCS
associate profile 2 register TRA_GW_TCS
associate profile 1 register CON_GW_TCS
keepalive retries 5
switchback method graceful
switchback interval 15
I have press correct answer accidentally can I remove that?
Sorry, no way to remove the rating, let's make we get it resolved for you :-)
Besides he SCCP group binding also bind SCCP via:
sccp local GigabitEthernet0/0
Chris
Yes
I already have this command.
sccp ccm 10.102.94.250 identifier 1 version 7.0
sccp
What IOS version are you using?
Can you replicate it with only Cisco IP phone participants?
Chris
15.1
In local I don't have problemas. The remote office uses avaya.
But I don't undertand why I using g711u. I have configured regions for each office and I've asociate this regions in diferents device pools. These device pools are asociated with the remote avaya gateway registered into the CUCM. They should communicate in g729 each other.
What region is assigned to the device pool used by the phone
What region is assigned to the device pool used by the conference bridge?
Now what codec is defined between these 2 regions or if the same one is assigned within this region?
Once way voice typically indicates routing issues, so you need to ensure that this gateway that has the CFB defined as full reachebility of the Avaya trunk and the other way around.
HTH,
Chris
Headquarter device pool.
The conference bridge uses the same Headquarter device pool
Yes uses the same region so speak g711. do I have to create a different device pool for conference bridge to speak 729?
With a normal call I don't have any problems between both destinations. The gateway and the CUCM have the same default gateway.
>> You have 2 choices if you want to use G729 for this participant (which by the way is not a cuase of your issue), you can either change the currnt Region to use G729 within itself or create seperate region for the conference bridge, assign it to new DP which apply to the bridge
This does not prove anything, what type of integration do you have in place between the Cisco solution and Avaya? Is it IP (i.e. SIP or H323) or is it TDM (i.e. QSIG)? With either solution no voice stram traverses CUCM unless you are using MTP on your IP trunk, so communication between CUCM and Avaya is irrelevant for RTP traffic.
Chris
Interesting.
I'm using a H323 trunk without MTP.
What do you recomend me to troubleshooting this? because I though the RTP stream use the same path regardless it would be a conference or a single call.
Thanks again.
Regards.
I recommand you confirm IP routing to/from Avaya CLAN card to the Cisco Gateway and/or from Avaya phones if they are IP to Cisco GW.
Also, see if the issue occurs only for Cisco IP phone participants, this wil prove if the issue is in fact routing to Avaya.
HTH,
Chris
Finally I've fixed it. Someone has changed the default route at the router. So when CUCM take the router's resources the RTP traffic through the router so the router sent RTP traffic to a wrong way.
Thank you.
