Config DIDs CUCM
nestor.gallego1
Hi Guys;
I have a SIP trunk directly to CUCM arrive without going through an MG. Outgoing calls are working properly. But the SIP toncal has a number of input when they dial from the PSTN should ring an extension registered in the CUCM. As I can make this configuration on the CUCM?
Thank you for your help
Deepak Rawat
Set the Significant Digits to match your dial-plan on the SIP Trunk under Inbound Calls
Deepak
Deepak Rawat
Deepak
Jaime Valencia
"But the SIP toncal has a number of input when they dial from the PSTN should ring an extension registered in the CUCM. As I can make this configuration on the CUCM?"
I have no idea what you mean by that, you'll have to rephrase, provide an example, or might want to try the spanish communities for this.
If you already have DIDs, simply map them to your phones, that's all you need to do.
java
if this helps, please rate
The question is clear, should you better rethink your answer is not the first time it's the same
