The call flow is CUCM >> sip gateway >> PRI. I am unable to make more than two inbound/ outbound calls. How to increase the number of inbound/ outbound calls in our voice network.
Hi everyone, I've configured a basic configuration for the VG320 analog gateway, ive copied pasted the running config in the gw. I'm not able to login anymore because i cannot retrieve the password. Is there a possibility to do a password recovery?
Dear All, I have 7821 phones registered with CUCM 8.5.1, but unable to make OffNet calls over SIP trunk, getting fast busy tone after keying in client matter code. Other phones with identical CSS & Partition and CMC are able to get through. What coul...
Hello Everyone, I have read following information cisco TAC presentation.Can you please explain me someone what is the function of CUCM IDS db and IDM db.Which information store this databases.Can you please give me some information. I know that CUC...
We have both sccp and sip phones with shared lines. When on SRST only the sccp shared line will ring for an inbound call but not the sip shared line. Is there a way to make this work or is this not supported? Manish
Customer is running Callmanager 10.5.2, and has implemented 802.1x authentication on the phones. Customer also has a NICE call recording solution in the mix. Once everything was configured, call recording began failing. NICE says 802.1x is not s...
Hi, I am migrating CME from the old router 38XX to a new router 29XX but I have a few questions below, just wondering if anyone can help? Can I migrate CME & SRST licenses from old 38XX to the new Router 29XX? If so, what would this process entail?...
Hi Guys Can anyone please verify me the following translation DID range 4227100-4227599 Ext ranges: 7100-7599 OUTBOUND voice translation-rule 1 rule 1 /^71/ /42271/rule 2 /^72/ /42272/rule 3 /^73/ /42273/rule 4 /^74/ /42274/rule 5 /^75/ /42275/! ...
Hello, We have an issue with listening to the voicemail and prompt message from Cisco Unity Connection. When tried to listen to it at the first time, the message is garbled When listened for the second time, it is already clear. May we know what mig...
One of our staff told me that when she calls from her Cisco 8945 phone to a cell phone number, the external person's phone shows: UNKNOWN or Restricted. I have made Desk Phone-to-Cell Phone test calls from various cell phone models and here is what...
HiI am using CUCM 9.1 and configured SAF between CUCM Cluster and CMEs. All CMEs are learning the patterns and inter calls are successfully made. CUCM side, SAF forwarder is learning the patterns also advertising. But I cannot see any learned patter...
Hi All, I want a billing software for PBX, i haven't any idea about the mark which i can use. thanks in advance
We have a few 8861's connected to the network via WiFi. Initially the phones worked fine. Now, if the user puts a caller on hold, when they retrieve the call, the caller could not hear the user. The only "change" was the addition of a few speed dials...
Hello We have four 7975g cisco phones ... they suddenly stopped working .. the only thing appear in the screen is on the attached picture
Hi,I have a Polycom IP6000 configured on our UCM 9.1 environment via SIP. Calls inside the network and inbound work fine. Outbound calls that are 7 digits work fine (9 + Local number). Outbound calls with an area code fail on the 10th digit before...
| Subject | Author | Posted |
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
