config RAID on MCS 7825 i5
youssef.erraki
Hello
I add a new HDD to my server ( MCS 7825 i5) that already bought with one HDD. now the server has 2 HDD.
My Problem is when I try to configure RAID 1 on my server it seem like the the controller not install.
so I need to make sure if the controller is installed otherwise Is there are any procedure to configure RAID on my server.
thank you for your relpys
Best Regards
yahsiel2004
Level 7
Level 7
Are you able to access the LSI configuration? Please reference the guide below:
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/ibm_doc_sraidbr_10i-0508_install-users-guide.pdf
Yosh
HTH Regards, Yosh
thank you for your reply it seem that not existe in the server I see with system ingeniere and he confirmed me that the card not existe in the server
thank you again for your reply
Gotcha!
Yosh
HTH Regards, Yosh
