04-09-2010 12:09 AM - edited 03-15-2019 10:10 PM
Hello
I have a "T2" connection from France Telecom. An ISDN30 (E1) was requested. Handoff is RJ45. A standard E1 config is not working. Does anyone have experience with T2 connections? As best I can tell, a T2 is essentially the same as an E1. Router is a 3845, connection can be H323 or MGCP back to a Call Manager. I could use help on the controller and serial configuration.
Right now I have:
controller E1 0/1/0
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
Thanks very much for any assistance.
04-09-2010 12:44 AM
Well, not sure what T2 is (the liquid Terminator wasn't it?)..
But most places in Europe outside the UK use 'framing no-crc' under your E1 controller config.
Try that...
Aaron
Please rate helpful posts..
04-09-2010 01:17 AM
Always begin with "show controllers E1".
03-21-2011 01:16 PM
We have the same problem.... Can you tell me how you go this thing to work. I have the exact same E1 Config on my router.
Abraham
03-21-2011 01:20 PM
Hi Abraham
I believe the root cause of my issue was physical. The connection from the Fance Telecom box to the router required a cross over instead of a standard T1 cable or a straight through. If you are still having issues - let me know and perhaps paste in your config.
-Doug
03-21-2011 01:44 PM
Thank you so much for the reply Doug.
I have copied the relevant parts of the Running Config and is given below.
Could you please review this.
network-clock-participate wic 0
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
controller E1 0/0/0
controller E1 0/0/1
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no cdp enable
Thanks in advance
Abraham
03-21-2011 02:07 PM
Hi Abraham
Here are the relevant pieces of my configuration, this is on a 2811. I am using H323 back to a CM 7. You will see mine is a fractional E1 so the timeslots are different.
card type e1 0 2
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
voice-card 0
dspfarm
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-16
interface Serial0/2/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/2/0:15
cptone FR
