02-02-2018 11:14 AM - edited 03-17-2019 12:06 PM
I have a request to configure a call routing or flow as follows:
Inbound call from pstn arrives on PRI attached to Cisco IOS gateway. The gateway is connected to Call Manager via SIP trunk. The request is for the inbound call to a particular number should ring to internal DN1 > ring to internal DN2 > ring to internal DN3 > ring to external cell phone1 > ring to external cell phone2 > ring to external cell phone3 > send to a VM box on Unity Connection.
The call should be sent to the next destination in sequence if that DN is busy or the call is unanswered.
We are running:
Unified CM and Unity Connection. Both are v10.5.2
Any suggestions would be appreciated on how this might be accomplished.
Mike
Solved! Go to Solution.
02-02-2018 12:57 PM
A line group can only contain CUCM's DNs, no external numbers. Phones in a line group with SNR will also ring the external devices. There is no way to hunt thru external devices with call forward settings as CUCM will lose all control of the call.
So, you need to configure 3 phones (with/without SNR up to you) as the 3 phones you want, + 3 phones WITH SNR to ring those external devices (adjust the timers so mobile's VM doesn't take the call), then use the CFNA/CFB from the hunt group to send to CUC.
02-02-2018 11:22 AM
02-02-2018 12:24 PM
Can you comment as whether it's possible to include external numbers in a hunt group. I've read some messages that say it can't be done. Of course I may have interpreted something wrong as well.
02-02-2018 11:45 AM
The only way to do that is to combine line groups + SNR
02-02-2018 12:26 PM
Please provide a few more details on what you mean by 'combine line groups + SNR'. I familiar with what SNR is and have configured it a few times but I don't see how I can match the call flow I'm being asked for with that.
Mike
02-02-2018 12:57 PM
02-02-2018 01:10 PM
I appreciate the explanation. I'll set this up and give it a try next week.
