Configure Access List to allow only 4XXX range.
frank3333
I need a help to configure 4300 extension allow only to dial 4(0-3)XX range. and other extension should be blocked.
Can we do it using access list config on call routing--> class of control --> access list.
thanks.
Hi frank3333,
 what are you using as a Call Control: CUCM, CUCME, other?
Regards.
Im using cucm 10.5
thanks
As Jamie (+5) Mentioned above, you need to use Partitions and CSS to achieve this.
Aditya Gupta
Jaime Valencia
No, that has nothing to do with what you're asking (those are used for Unified Mobility), you need to use CSS/partitions, if you're not familiar with that, read the dial plan chapter from the SRND to understand how they work.
java
if this helps, please rate
