ā12-16-2013 09:29 PM - edited ā03-16-2019 08:53 PM
Dear Support Team,
I have to setup an E1 on a router to enable me route voice calls to the PSTN how can i achieve that.
a. can i use the normal ethernet RJ45 cable for the E1 connection ?
ā12-16-2013 11:21 PM
Hello Jude,
You ca use the RJ45 cable.
The following document will be of some help in understanding the pinouts of an RJ45 cable :
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008010059a.shtml
https://supportforums.cisco.com/thread/24328
For the configuration part, you need to first decide the protocol (H323/MGCP).
ā12-17-2013 06:43 AM
+5 for Sambit for good answer. In addition RJ45 is OK for straight through E1/T1 cable as the pinouts are the same, however if you need to use cross-over then you cannot use RJ45 Ethernet crossover and need to use RJ48 where pin 1 is crossed with 4, and 2 is crossed with 5.
HTH,
Chris
ā12-19-2013 01:53 AM
What is the config on the router to enable the card work on the router ?
ā12-19-2013 01:58 AM
card type e1 x x ( x = what slot the card is on)
network-clock-participate wic x
network-clock-select 1 E1 x/x/x
isdn switch-type primary-net5
controller E1 x/x/x
pri-group timeslots 1-31
interface Serialx/x/x:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
voice-port x/x/x:15
cptone xx (your country code)
ā12-19-2013 01:59 AM
What are you trying to configure ? I mean E1 PRI or E1 CAS ?
For E1 PRI check this link :
https://supportforums.cisco.com/docs/DOC-29718
For E1 CAS:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
Br,
Nadeem
Please rate all useful post.
