Configure multiple extensions registered on multiple Call managers
Wonxie
Is it possible to configure second extension on CIPC that is registerd to another Call manager cluster and that call manager cluster has been linked via intercluster sip trunk ?
besides softphone is it possible on hardphone 6941 ? there are 4 lines on it can i configure line 1 with extension that is registered on cluster 1 and line 2 with another extension that is registered on cluster 2.
Regards.
Jaime Valencia
No, that's simply not possible.
A device can only register to one CUCM cluster.
java
if this helps, please rate
Jaime Valencia
java
As Java wrote, this is not possible.
Response Signature
