configuring an announcement before connecting a call in cucm/unity
feisalb
Hello All
I have a customer that whats callers to hear an announcement before the call is connected / passed to the correct destination number.
System is cucm 8.6 and cucx.
Can this be done via a call handler?
If so are these the correct steps:
I need to create a cti in cucm with all calls fwd to vm.
create a forwarded routing rule
create a system handler
     Transfer rule -> go directly to greeting
     Standard greeting
     Caller hears: my personal recording
     After Greeting: ???? (this is where I am stuck as the user doesn't have mail box)
Also they want a 2 sec wait before ringback (is that a  cucm parameter).
Any help is appreciated as usual.
Feisal
Jaime Valencia
You need another call handlers with transfer options set to whatever phone number you want, as the last step for after-greeting.
after-greeting->attempt transfer to -> call handler with transfer options ser to XXXX
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Nishant Savalia
Level 4
Level 4
Hi Feisal,
Please check the below link if it's useful
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsextcallctrl.html#wp1420583
Thank You
Nishant
Regards, Nishant Savalia
