Configuring ATA 187
I need to add and configure an ATA 187, but I can not find the configuration option for this device.
Can I add this option to the Cisco Call Manager?
Aman Soi
Hi Nicolas,
What is CUCM version u are using?
ATA 187 is supported on CUCM Versions 7.1.5, 8.0.2, or higher.
Can u share the error snapshot of CUCM?
regds,
aman
Thanks for your help.
The version is 7.1.5
You'll need to download and install the latest device pack for 7.1.5
GTG
Please rate all helpful posts.
Hi Nicolas,
You can download the latest version 9.2(3). Before u do that , u need to install QED [Quick Enabler Device ].
The same can also be downloaded from below link.
http://software.cisco.com/download/release.html?mdfid=283118514&flowid=30821&softwareid=282074215&release=9.2(3)&relind=AVAILABLE&rellifecycle=&reltype=latest
regds,
aman
