Configuring Cisco CP-7821 - Programmable Soft Keys
saviopereira1
   Can someone please help me, I am trying to customise the Programmable soft keys on the CP-7821 but for some reason the changes are not taking effect.
Current firmware: sip78xx.10-3-1-11-3PCC
Thanks in advance,
Sav
Adarsh Chauhan
Level 3
Level 3
Hi Sav,
I researched a bit and 3PCC firmware do not support softkeys.
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
5 Replies 5
Adarsh Chauhan
Level 3
Level 3
Hi Sav,
Adarsh Chauhan
Adarsh Chauhan
Hi Adarsh,
   Thanks for your help, Is there any other firmware release that could help me achieve this or How to perform a Firmware upgrade ?
Savio
are you using CUCM?
you may go to an enterprise version (cmterm-78xx.11-5-1SR1-1.k3.cop.sgn) however i have seen a challenge and also read few articles where you might not be able to go back to 3pcc firmware.
Please rate and mark if helpful
Adarsh Chauhan
Adarsh Chauhan
   No, I'm not. I'm using it on Asterisk hosted services. I can't seem to modify the Programmable softkey. I have seen that Cisco has released a new firmware, "cp-78xx-sip.10-4-1SR1-3-3PCC". I have tried upgrading thecurrent one to this one but had no luck.
Can you please advice.
Savio
    I have just managed to upgrade the Cisco CP-7821 to a new firmware, "cp-78xx-sip.10-4-1SR1-3-3PCC" using http file server. The programmable keys work on this firmware.
The issue appears to be resolved now.
Cheers,
Savio
