I have a Cisco 2921 Router that has a 4 FXO card in it. I would like to configure it so that ALL incoming calls on all 4 ports to be fowarded to a internal extension (1001), this is for a test environment and I can't seem to figure out what I am missing. The config is below:
Building configuration...
Current configuration : 8500 bytes
! Last configuration change at 08:19:46 EST Fri Mar 1 2013 by jmartin
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service sequence-numbers
hostname WH-VOIP-2900
boot-start-marker
boot-end-marker
logging buffered 10000000
aaa new-model
aaa authentication login default group tacacs+ local line
aaa authentication login NOAUTH none
aaa authorization exec default group tacacs+ local none
aaa authorization exec NOAUTH none
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa session-id common
clock timezone EST -5 0
clock summer-time EST recurring
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name mgsd.edu
trunk group FXO
crypto pki trustpoint TP-self-signed-3979560690
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3979560690
revocation-check none
crypto pki certificate chain TP-self-signed-3979560690
certificate self-signed 01
3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393739 35363036 3930301E 170D3130 31323232 31333533
30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373935
36303639 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100DD47 9227149F 2D084CE5 3D227595 7DBF4FCA C3519000 3F468821 D56F653A
E74FCBAD B4936598 F0C26B2B 6132ADE7 1B1BDC89 44D3C53F 63DDAF78 8E08FCA7
7044095A DBE38889 7CD48871 94ED1CF9 F2ECC50A 8BD21AFC 5BC3B3FC B322E161
F3CE339A 88AA803B E3705349 03A7D918 C11E5844 ECF039EB FEC44CDF 52A59AE5
0C430203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
551D1104 19301782 1557482D 564F4950 2D323930 302E6D67 73642E65 6475301F
0603551D 23041830 16801463 9BA90049 2F6005DC F2A35FC3 329D4138 0EDB2530
1D060355 1D0E0416 0414639B A900492F 6005DCF2 A35FC332 9D41380E DB25300D
06092A86 4886F70D 01010405 00038181 005C2C45 9F687AEF 3219F567 337E55CD
9E524A1B 7879B3B1 F3C872F9 DFF7F014 FFE0D84B 67252EFE 3DFF8959 9565ADE2
79857E34 FFF2C3DE 667D5D62 8A4E4690 D874CF4A 8B180832 7748D1E8 BB71543B
BC404126 02DABACB DDF24EE6 6F63F8CE F7F8494C 66115C77 B768BC77 DA2D5C2C
984DC376 A16F2B81 D1CBD44F F23B8605 D4
quit
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
call start slow
call preserve
license udi pid CISCO2921/K9 sn FTX1448AJ6B
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$iKc/$uQJli0iQG9VAu4PiFeYC8/
redundancy
interface GigabitEthernet0/0
description to Inside LAN
ip address 10.40.0.51 255.255.0.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.40.0.51
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.40.0.1
snmp-server community mgsdvoip RO
snmp-server community mhsswitch RO
snmp-server location "Mooresville High School"
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps flash insertion removal
snmp-server enable traps energywise
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps entity
snmp-server enable traps hsrp
snmp-server enable traps cpu threshold
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps srst
snmp-server enable traps voice
snmp-server host 10.65.0.252 version 2c mgsdvoip
snmp-server host 10.10.0.252 version 2c mhsswitch
tacacs-server host 10.60.253.10 key Pa$$word
tacacs-server directed-request
control-plane
voice-port 0/0/0
trunk-group FXO 1
connection plar 1001
description 704-799-0516
voice-port 0/0/1
trunk-group FXO 2
voice-port 0/0/2
trunk-group FXO 3
voice-port 0/0/3
trunk-group FXO 4
description ==> To 911
sccp local GigabitEthernet0/0
sccp ccm 10.65.0.63 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate profile 1 register WH-2900_CFB
associate profile 2 register WH-2900_MTP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions hardware 2
dial-peer voice 1 pots
trunkgroup FXO
incoming called-number .
dial-peer voice 2 pots
destination-pattern 9[2-9]11
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
port 0/0/3
forward-digits 3
dial-peer voice 3 pots
destination-pattern 911$
port 0/0/3
forward-digits all
dial-peer voice 4 pots
trunkgroup FXO
destination-pattern 9[2-9]..[2-9]......
forward-digits 10
dial-peer voice 5 pots
trunkgroup FXO
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 6 pots
trunkgroup FXO
destination-pattern 9011T
prefix 011
dial-peer voice 32 pots
trunkgroup FXO
description SRST 4-digit dialing to other sites
destination-pattern 2...
forward-digits all
prefix 704658
dial-peer voice 100 voip
preference 1
destination-pattern [2]...
progress_ind connect enable 8
progress_ind disconnect enable 8
session target ipv4:10.65.0.23
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax rate 14400
ip qos dscp cs5 signaling
no vad
dial-peer voice 101 voip
preference 2
session target ipv4:10.65.0.63
voice-class codec 1
voice-class h323 1
fax rate 14400
no vad
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 10.40.0.51 port 2000
max-ephones 50
max-dn 100 dual-line
system message primary Phone is in Standalone Mode
system message secondary Standalone Mode
dialplan-pattern 1 7046582... extension-length 4
transfer-pattern .T
keepalive 10
voicemail 2525
call-park select no-auto-match
call-forward pattern .T
call-forward busy 97046582525
call-forward noan 97046582525 timeout 16
date-format dd-mm-yy
vm-integration
pattern direct *** CGN
pattern ext-to-ext no-answer 5 FDN * CGN *
pattern ext-to-ext busy 7 FDN * CGN *
pattern trunk-to-ext no-answer 4 FDN * CGN *
pattern trunk-to-ext busy 6 FDN * CGN *
line con 0
password V01pG8te
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password V01pG8te
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
password V01pG8te
line vty 16 1114
transport input all
scheduler allocate 20000 1000
ntp server 129.6.15.29
end
Solved! Go to Solution.
Jeff,
I am assuming that the voip dial peers 100 & 101 are pointing to a CuCM?
The destination pattern on the voip dial peers doesn't match 1001 set on the PLAR and they need changing to something like:-
dial-peer voice 100
destination-pattern [12]...
dial-peer voice 101
Hope this helps,
Craig
PLEASE RATE HELPFUL POSTS
Jeff,
What happens when you m ake a test call.where does the call go?
can you send us debug vpm signal and debug voip ccapi inout
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Jeff,
dial-peer voice 100
dial-peer voice 101
Hope this helps,
Craig
