Configuring ISDN T1 issues
jjcollaguazo
Just wondering if anyone has experience the follwoing.
For some reason when i enter the follwoing commands they don't show in my config. I don't get an error message when i enter them and i can also enter different types which are visible when i do a sho run. Also when i enter the cptone US command on the voice port the command doesn't show.
controller T1 0/0/0
framing esf
linecode b8zs
Here's my relvant config.
card type t1 0 0
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
isdn switch-type primary-ni
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
description *** ISDN XX ***
controller T1 0/0/1
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:23
The IOS is c2800nm-spservicesk9-mz.124-24.T5.bin and the module is VWIC2-2MFT-T1/E1
Any help woul be much appreciated as i've never had to configure ISDN for the US.
Cheers,
bettear
Default commands often aren't listed.  Try "show run all" and you should see everything.
bettear
Bingo! Thanks for reminding me about the obvious.
