Configuring offnet and on-net access code on cisco cme 2951
I want to know how can I configure on-net and offnet access code on cisco cme.
Aristide
8 Replies 8
Jaime Valencia
For off-net, you can configure FAC, the CME configuration guide covers this, not sure exactly what you want for on-net, in the end, it's all dial-peers.
java
if this helps, please rate
Hi Jaime,
hope you're doing well. I want to know if you are talking about Features access code or force authorization code.
Forced Authorization Code
java
Can I use "afterhours and pin override" to do it?
FAC on CME (2951 router) is called COR (Call of Restriction).
Please follow this guide:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
No, that's wrong, FAC and COR are two separate features.
java
Thank you Jaime, I want to know if I can use afterhours and pin override to do FAC?
I'm trying to configure fac but it doesn't work. See my configuration below:
voice register pool  120
 pin 1234
 lpcor type local
 lpcor incoming TRUNK
 busy-trigger-per-button 2
 id mac E0D1.73E4.2AFD
 type 7841
 number 1 dn 120
 cor incoming local-outside default
 dtmf-relay rtp-nte sip-notify
voice lpcor enable
voice lpcor custom
 group 10 TRUNK
voice lpcor policy TRUNK
 service fac
 accept TRUNK fac
voice translation-rule 1
 rule 1 /\(^8\)/ //
 rule 2 /\(^9\)/ //
voice translation-rule 2
 rule 1 /\(^0\)/ //
voice translation-profile DiscardDigit0
 translate called 2
voice translation-profile DiscardDigit89
 translate called 1
application
 package auth
  param max-retries 0
  param passwd-prompt flash:enter_pin.au
  param abort-digit *
  param term-digit #
  param user-prompt flash:enter_account.au
  param max-digits 32
voice-port 0/0/0:15
 lpcor outgoing TRUNK
dial-peer voice 1 pots
 corlist outgoing local-outside
 description Outgoing-calls
 translation-profile outgoing DiscardDigit0
 destination-pattern 0T
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
please guys,
I need your help!
