Configuring SIP trunks from Cube to ISP
carl_townshend
Hi All
When setting up a SIP trunk to an ISP using a CUBE, What kind of details do you normally put in?
I am guessing you need a session target IP for the ISP?
Do they also have to configure the same from their end and point to an IP that you give them?
M02@rt37
Hi @carl_townshend
Yes you will configure on your CUBE:
-session target ipv4:@《remote ip @》
-Destination pattern XXX
-Perhaps you will need transformation profile too.
-session protocol sipv2
On the other hand they will need the ip @ of your CME in order to configure the trunk sip.
Best regards
Chris Deren
I would suggest starting with the CUBE configuration official guide:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book.html
which covers all details.
Jaime Valencia
Ratheesh Kumar
This guide can help you. Basic config
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117300-configure-cube-00.html
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
