Convert SCCP to MGCP FAX on VG2XX Gateways
robin99
I have clients using SCCP on their VG248 and VG224 devices. Now they want to use provider SIP trunk which does not support NSE switchover for faxes. Is there a way to convert those gateway protocols from SCCP to MGCP easily on UCM 8.6?
regards,
Robin
Dragan Ilic
Level 4
Level 4
Sure it's possible - you can even have both of them on same gateway for controlling so you can slowly transition from one to another. More on MGCP config for VG2xx cisco.com...
BR,
Dragan
HTH,
Dragan
unfortunately I do not have luxury of time (downtime) for making changes line by line. I am hoping there is more automatic tool/ way to change that protocol. Say one/ few steps to convert the VG248 SCCP to MGCP without changing each of port settings.
Would this be available on UCM system?
