08-20-2015 09:12 AM - edited 03-17-2019 04:03 AM
How can you convert Cisco 7821 SCCP Phone to a SIP Phone ?
08-20-2015 09:32 AM
Do you have CME or CUCM?
Br,
Nadeem
08-20-2015 09:37 AM
None, I'm trying to use the phone with hosted VoIP services.
08-20-2015 09:44 AM
There are many blog available on google converting Cisco IP phone from SCCP to SIP here are some.
Please refer the same.
http://www.voipsupply.com/blog/voip-insider/tech-tip-converting-a-cisco-ip-phone-from-sccp-skinny-to-sip-firmware/
http://www.3cx.com/blog/docs/cisco-7940-sip/
Br,
Nadeem
08-21-2015 02:33 AM
Your 7821 IP phone must already be working with SIP.
There's no Skinny for 78xx nor 88xx nor newer IP phone models.
08-21-2015 04:30 AM
rootfs78xx.10-2-1-12SR1-4 | ||
Boot Load ID | sboot78xx.6120-10-2-1-12SR1-4 | |
Version | sip78xx.10-2-1-12SR1-4 | |
Hardware Revision | V02 | |
Model Number | CP-7821 |
The phone is displaying "Phone Not Registered message" ... How can i get the phone configured through tftp ?
08-21-2015 07:28 AM
You need your VoIP hosted server to have the tftp file and you need DHCP options to point the phone to the hosted VoIP server.
08-21-2015 09:57 AM
Hello Ahmd,
As Mohammed said you need to configure option 150 on the DHCP so you can point out the TFTP server to the IP Phones and they should be able to reach it so they can download the .xml config files for the phones.
Also check which VoIP system and version are they using on the voip hosted services to see if it supports the 7821 or if they need to upload the firmware or a devicepack and then restart the TFTP Service on the system.
