Corporate Directory integration with CUCME
techguy
Level 4
Level 4
Further to the subject matter, so far i have succeded to integrate corporate directory in one direction (meaning CME IP Phones can see corporate directory) but i am still not able to do it in other direction (meaning IP Phones registered in CUCM cant see CME IP Phones).
Anyone who did it or have idea to fix it? Thanks
techguy
Level 4
Level 4
I think CUCME can also be integrated with direct Active Directory as CUCM is also taking users information via Active directory.
Not natively, but you can write your own custom directory script for that purpose
java
if this helps, please rate
Hi all,
      Can you tell me how did you do it? or paste some documents or guide to do it? Thanks in advanced.
Regards.
