04-16-2013 05:54 AM - edited 03-16-2019 04:49 PM
HI to all
in our company if the user need to search in the Corporate Directory every time he must registration with the and Password
We upgraded our CUCM from Call Manager 4.1(3) to 8.6
before we search in the directory with out Login.
Now when you open the corporate directory on the phone every time i must login with my ID and PW
we don't Integration any external LADP or Microsoft AD with our CUCM (Local End Users)
Is there any solution for this Case ?
Thank you all for Help
04-16-2013 05:58 AM
Corporate directory does not require login, personal directory does, are you sure you are using corporate and not personal directory?
Chris
04-16-2013 06:09 AM
Sorry I mean personal directory.
04-16-2013 06:31 AM
Hi.
Since is not possible to avoid userid and pin request for personal directory, there are some workaround that you can find in this post https://supportforums.cisco.com/thread/2102038 or this doc https://supportforums.cisco.com/docs/DOC-1385
Carlo
05-26-2023 10:02 AM
Hello Carlo,
Could you please update the posts ? These are removed.
Alternatively, please post the answer itself.
Much obliged.
05-26-2023 10:24 AM
You do realise that this post is more than 10 years old? Apart from that as you’re a Cisco employee you have other internal resources to seek out information. This community is not the appropriate place for you to ask questions.
