Showing results forĀ
Search instead forĀ
Did you mean:Ā
CP-7841-3PCC-K9 phone shows incorrect time
RaymondCarr7496
My CP-7841-3PCC-K9 IP phone's displayed time-of-day is off by 5 or 6 minutes (behind). The date is fine. I'm trying to figure out what is causing this. I don't see any NTP settings in the phone's web interface. My router's time is correct. I also have a Cisco 7912G IP  phone which displays the correct time.
Update: found NTP setting in the Voice/System advanced settings
2 Accepted Solutions
Geovani
Please set your NTP server on the web interface Voice --> System
What firmware version are you using?
George Sotiropoulos
You will need to use the web-interface of the phone and select Voice ->System -> NTP Server
Hope this helps,
George
Hope the above helps,
gsotirop
Geovani
George Sotiropoulos
Hope this helps,
George
gsotirop
