08-01-2012 01:47 AM - edited 03-16-2019 12:28 PM
Hi Guys,
Cam across this will trying to correct the time. I wanted to confirm that the time was actually correct...thing is, the other phones display the time...but this one does not display time on the web interface. Is this normal?
Solved! Go to Solution.
08-01-2012 01:53 AM
What firmware and CUCM/CME version you are running. I suspect firmware issue. May be you can upgrade it and see if it gets resolves.
regards
Ronak patel
Rate helpful posts.
08-01-2012 01:53 AM
regards
Ronak patel
Rate helpful posts.
02-27-2013 04:48 AM
Thank you. It was a firmware issue
