CP-8821, ISR4331, files for phones and CUCME
leam2
I have Cisco CP-8821 phones and an ISR4331 with CUBE and CUCME functionalities.
According to this document:
"10 Step to configure Cisco Call Manager Express"
https://mrncciew.files.wordpress.com/2013/07/how-to-configure-cme.pdf
- at step 5, I would need a file like "cme-full-4.3.0.0.tar"
- at steps 6 and 7, I would need some ".sbn" and ".loads" files for the phones.
I can't find these files on the ISR4331 that I have.
1. Where should they be located?
2. If they are missing, is there a repository where I can download them?
Please help me.
Best regards.
12 Replies 12
R0g22
The files that you mention are phone firmware files and don't come pre-loaded from the factor. You can head over to CCO and download the files if your ID has an active software download contract.
Hello.
I've bought my products but received no ID to download any kind of software or files.
Therefore, I have no idea what "CCO" and "software download contract" are.
I am in a great trouble because I can't autonomously download the software and files that I need to configure my products.
R0g22
Open the following link and login -
https://software.cisco.com/download/home/286308995/type/282074288/release/11.0%25283%2529SR6
Do you see a "Additional Entitlement Download" or are you able to download the firmware ?
Hello.
Indeed, I am able to download the firmware. That is good.
May I ask you about the other file I mentioned in my initial post:
"10 Steps to configure Cisco Call Manager Express"
Can I get this file or a more recent one too?
R0g22
Good, than that means you have a valid contract.
Now, you don't need CME 4.0 package. Do you have CME running on the router yet i.e. with telephony-service or voice register global ?
If yes, do a "show telephony-service" or "show voice register global" to check the CME version. Then download the relevant CME version package here -
https://software.cisco.com/download/home/277641082/type/282786567/release/12.2
Hello again.
I found this file "CME-COMPLETE-FILESET-12.2.tar" which may be a replacement for "cme-full-4.3.0.0.tar" but I've no idea about that...
I am not allowed to download it as you can see in the image below:
CME-COMPLETE-FILESET-12.2.tarCME-COMPLETE-FILESET-12.2.tar
R0g22
Yup, you won't be able to. Talk to your AM regarding and get the contract assigned to your profile if you have already purchased it or you would need to purchase one.
Hello. Sorry, I didn't see your intermediary answer.
isr4331# show telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address UNKNOWN port 2000
ip qos dscp:
 ef (the MS 6 bits, 46, in ToS, 0xB8) for media
 cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
 af41 (the MS 6 bits, 34, in ToS, 0x88) for video
 default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 0
max-dn 0
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
isr4331#show voice register global
CONFIG [Version=10.5]
  Version 10.5
  Mode is srst
  Max-pool is 0
  Max-dn is 0
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Allow-hash-in-dn is disabled
  Forced Authorization Code Refer is enabled
  timeout interdigit 0
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
  MWI unsolicited notify is disabled
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   :
    Last unregister request time :
    Register success time        :
    Unregister success time      :
Nipun Singh Raghav> Yup, you won't be able to. Talk to your AM regarding and get the contract assigned to your profile if you have already purchased it or you would need to purchase one.
What do you mean by "AM"?
Is this compulsory to get this file to have the system work properly?
In other words, in the document below, can I skip "step 5" without any problem?
R0g22
AM = Accounts Manager.
No, it's not mandatory. What were you looking for in that package ?
Hello.
I wasn't looking for anything special (for now).
I just want to do the minimum configuration I can with: two wireless phones CP-8821, an ISR4331 with CUBE and CUCME features, a Catalyst Switch (WS-C2960L-24TS-LL) and a Wi-fi WLC/access point (AIR-AP1832I-E-K9).
I need to complete the steps in that document I mentioned earlier ("10 Steps to configure Cisco Call Manager Express") to make my system operational.
Is there a means to know just the contents of this archive ("CME-COMPLETE-FILESET-12.2.tar"): the files list with their names and maybe what they are useful for?
R0g22
The package contains - background images, ringtones, b-acd tcl scripts, moh file, GUI files etc.
There is nothing in the package that is required for phone registration. Its more
from a customization perspective.
Hello.
Ok. Thank you very much.
I'll do without it then for now.
