CP-8841 configuration for use as SIP phone.
jarmund
I have a stack of CP-8841 phones that were handed to me. They have all been reset to factory default.
Unfortunately, it does not appear to be listening to port 80 for configuration via WebGUI, so after some research I've looked into configuring it via tftp instead. I've spent more time than I'd like to admit getting this up and running.
I have set up a TFTP server, and I have confirmed that the phone is grabbing a test-config from my tftp. Said configuration does of course not match neither the phone model or use case, I just wanted to confirm that the config upload works. It is uploaed and applied successfully (as confirmed by both my tftp server logs, and some "new" settings showing up on my phone). Still no webGUI, though, despide the config having the <webAccess>1</webAccess> inside both the VendorConfig and enterpriseConfig tags.
My question is therefore twofold:
1) If I could just get the WebGUI up and running, I can do the rest from there. What is a basic barebone configuration I can upload via TFTP to enable WebGUI?
2) If WebGUI is not possible, how do I create a config from scratch with my settings? I only need the very basics, so I have an address, a username, and a password. I also have some preferences when it comes to codec, but I'm not picky. It's also in an internally secured network, in a secure area, so allowing full access for whoever is on the network and physically on site is not a concern.
Running firmware sip88xx.12-0-1RS1-1
I do not have a local PBX, CUCM, or anything like that available.
6 Replies 6
The 8800 series phones are designed to speak to some kind of Cisco PBX, whether that is CUCM or CUCME. There is a version of the phones (the sticker on the back will say "3PCC" as part of the PID on the back) that are designed to work with 3rd-party (non-Cisco) SIP PBXes.
You can change from one mode to the other by changing the firmware. But I don't believe the phones will work as stand-alone devices even in the multi-platform mode.
Maren
The phone would need to be registered with some kind of call processing engine. It can not operate on its own.
Response Signature
Leo Laohoo
Whether the phone runs on Enterprise image or 3PCC/MPP firmware, the phone can be integrated with Asterisk- or 3CX based call servers.
For Enterprise image, integrating to Asterisk- or 3CX based call servers will take some bit of time and effort because each firmware version has different behaviours.
Michael23
Does anyone know how to or can direct me where to learn how to change the firmware to 3PCC
ben123123123123
The Download doesn't work. I am logged in but the download doesn't work. https://software.cisco.com/download/home/286255327/type/282074288/release/14.2(1)SR2
