IP Telephony and Phones
Labels
Hello, I am running a problem with the UC500 platform and I am hoping for some advice.I'm using a UC540W as a small pbx with a variety of internal extensions. The uc540 is connected on a private LAN with NAT access to the Internet, the NAT router als...
sam2000 by Level 1
  • 6195 Views
  • 40 replies
I need to know if this can be done. I need to have one specific inbound number that is dialing a line group to be sent over to a specific extension. When I receive a call from xxx-xxx-xxxx I need to have it sent to extension yyyy. Is that possible an...
apowers by Level 1
  • 1306 Views
  • 2 replies
  • 1 Helpful votes
Helloi have cucm Pub and SUB01, before i add 02 sub to cluster, after issue with cluster i have removed 2 SUB from cluster , from gui Pub and SUB but when i run run sql select * from processnode in PUB it show SUB01 ip and PUB ip no présence of delet...
kingstdz by Level 1
  • 236 Views
  • 0 replies
We have seen a steep increase in Dialer Call result 9 "Customer phone was busy" and a drop in Dialer Call result 2 "Error condition while dialing" Call Result 2 was trending at approximately 700 dials/per day which has now dropped to 0. Most of the n...
JosephSP by Level 1
  • 283 Views
  • 0 replies
Hello,I'm running CUCM 11.5 and I have a CP-8841 phone that is being re-assigned to a user.The cluster is 1PUB/3SUBs with a CUCM Group set to auto-register.The phone in question will register in CUCM with an auto-registered DN , an IP Address in the ...
