CP-8841 phone lacks idivert function
mxelkin
Some of the 8841 documentation says the phone supports idivert function.  This does not seem to be the case with CUCM 8.6.2.
Sure it is, it shows up on the phone as "Decline" softkey, but besides different label it is the same feature.
10 Replies 10
Jaime Valencia
This is Video Over IP, please move to the right area
java
if this helps, please rate
Chris Deren
Do you have "Divert" enabled in the feature control policy?
Chris
We can't find that setting in the feature control policy.
Go to Device --> Device Settings --> Feature Control Policy, where you need to create one if you don't have it and enable:
Divert (Alerting)
Divert (Connected)
then assign this feature control policy to the phone.
Chris
Tried that and failed.  The menu item does not exist.  It does for the 9971.
Looks like on these phones it is showing as "Decline" via soft key, check out:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8841_8851_8861/10_5/english/admin_guide/P881_BK_AA5170E9_00_adminguide-8841-8851-8861-10_0/P881_BK_AA5170E9_00_adminguide-8841-8851-8861-10_2_1_chapter_01011.html
Chris
Neither Decline nor Idivert are there.  This appears to be a bug in 8.6.2.  Have not tried this in 10.5 yet.
Thanks for the info. I recreated in the lab and the idivert soft key is the one which shows as decline option when a call is coming in.
Decline All:
Allows a user to transfer a ringing, connected, or held call directly to a voice-messaging system. When a call is declined, the line becomes available to make or receive new calls.
See the Cisco Unified Communications Manager Features and Services Guide, "Immediate Divert" chapter.
CUCM Feature and service guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_0100001.html
