05-15-2020 02:01 AM
hi
I have some IP phone registered to cucm, there is a phone display a fork nearby the Directory number , but the phone registered to cucm is OK, and call is good.
05-17-2020 11:19 PM
Can you confirm that on this specific DN you have enabled all the "Name Information" fields such as, "Alerting Name", "Display (Caller ID)"?
George
05-18-2020 08:39 AM
05-19-2020 02:51 AM
05-19-2020 05:35 AM - edited 05-19-2020 05:47 AM
Thanks for your feedback,
I am almost sure that the X is the first Letter of Xiaoxia.Jia, so for the sake of clarify, try to change the 3 fields that you've mentioned for example to "George Sotiropoulos", I believe you will see next to the number "GS" instead of "X"
05-25-2020 07:28 PM
Thanks for your reply, but the customer has replaced anothe phone, it's ok , and he has not test to change that 3 label text.
In the future, if he test that I will update here.
