CUAC Advance 12.0.5 compability matrix with CUCM 12.5
KY_
Level 4
Level 4
Hi All
I have a smilar question for CUAC 10.5.2 and CUCM 12.5 so my question that CUCM 12.5 is compatible CUAC 12.0.1 I can not see this information on the compability matrix ?
I can not see that cucm 12.5 and cuac 12.0.5 is compatible or not this document may required to update.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-attendant-consoles/118861-technote-cuac-00.html#anc9
KY_
Level 4
Level 4
Hİ Nithin
Thanks for your quick response, I was forget looking at this guide.
thanks
Jaime Valencia
The CUACA RN as well as the design guide contain that information.
java
if this helps, please rate
