CUBE Asymmetric DTMF inter-working
noobatron
Hi all,
I'm having issues with inbound calls from a SIP ISP to a PABX connected endpoint failing due to DTMF RTP-NTE when DTMF dynamic payload type 97 is advertised in the INVITE. As such, i'm trying to configure asymmetric payload for DTMF interworking so that DTMF dynamic payload type 101 is used for the call leg from the CUBE to CUCM instead of 97 as received from the ISP with no luck. Dynamic PT 97 is still being sent to CUCM.
Topology
SIP ISP === [CUBE enterprise] ===== [CUCM] =====[MGCP GW] ==< QSIG E1>=== [PABX]-------- [phone]
Scenarios
  • Inbound SIP PSTN calls to with dynamic payload type 101 (a=rtpmap:101 telephone-event/8000) are successful
  • Inbound SIP PSTN calls to with dynamic payload type 97(a=rtpmap:97 telephone-event/8000) are successful
Configurations
  • No media resources configured for transcoding on CUCM (by design)
  • No MTP in use (by design)
  • Transcoding configured on CUBE
  • SIP Trunk on CUCM to CUBE DTMF signalling method: no preference
CUBE
voice service voip
ip address trusted list
<omitted>
address-hiding
mode border-element license capacity 100
allow-connections sip to sip
fax protocol none
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
asserted-id pai
outbound-proxy <omitted>
asymmetric payload full
midcall-signaling passthru
privacy-policy passthru
sip-profiles 10
dspfarm profile 10 transcode
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 28
associate application CUBE
dial-peer voice 1001 voip
description ** Outgoing via CUCM **
huntstop
preference 1
destination-pattern <omitted>
session protocol sipv2
session target <omitted>
voice-class codec 10
no voice-class sip outbound-proxy
rtp payload-type nte 101
voice-class sip asymmetric payload dtmf
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 2000 voip
description ** Incoming from SIP PSTN **
translation-profile incoming PSTN-Inbound-Calls
rtp payload-type nse 99
incoming uri via 2000
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte digit-drop
fax protocol none
dial-peer voice 2001 voip
description ** Outgoing via SIP PSTN **
translation-profile outgoing PSTN-Outbound-Calls
session target sip-server
destination e164-pattern-map 2000
voice-class codec 10 offer-all
voice-class sip profiles 2000
fax protocol none
Any ideas?
Thanks.
5 Replies 5
Deepak Mehta
Hi Nooba,
Nice explanation!Does it work when you have same payload type 97 on both call legs( ITSP-CUBE and CUBE CUCM)?
If you read other threads on this payload types have to match otherwise this doesn't work.
https://supportforums.cisco.com/discussion/12616466/rtp-nte-payload-type
Deepak,
This depends on the version of CUBE you are running..CUBE 1.4 and above does DTMF inter working without any issues. DTMF payload is not negotiated as done with codecs. PT is a more a declaration of what I can do and you should be able to send DTMF using the PT that I have advertised.
Please refer to the link below for more detail
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-dymc-payld-dtmf.html
Please rate all useful posts
+5 .This is certainly a grt forum where we want to give precise and correct info. Thank you and pls do correct me if anywhere my answers are incomplete.
Hi Ayodeji,
I've attached the sanitized debug below
Observations:
    • CUBE interface:10.1.1.16
    • ISP address: 192.168.1.167
    • CUCM: 172.16.75.75
    • Calling number: 00412312312
    • Called number 394564564
    • Outgoing Dial-peer to CUCM: 99 (same configuration as 1001)
Dial-peer voice 99 voip
huntstop
preference 1
dtmf-relay rtp-nte
fax rate disable
no vad
CUBE#sh debugging
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled (filter is OFF)
CUCM: 172.16.75.75
CUBE#term mon
CUBE#
2761955: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:394564564@10.1.1.1.16:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.167:5060;branch=z9hG4bKddia7t30a8sk2urjt0q0.1
From: <sip:416961513@10.83.154.138;user=phone>;tag=686768483-1463064231738-
To: "394564564 394564564"<sip:394564564@acme.company;user=phone>
Call-ID: BW004351738130516-532929662@10.83.154.138
CSeq: 313933726 INVITE
Contact: <sip:416961513@192.168.1.167:5060;transport=udp>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 29
Content-Type: application/sdp
Content-Length: 523
v=0
o=BroadWorks 10485621 1 IN IP4 192.168.1.167
s=-
c=IN IP4 192.168.1.167
t=0 0
a=sendrecv
a=media-release:hngl5rp9pujvivh05pvu6ibgr83pvg90756s7s8auvmg62o6u724c2sr96v3nd0v0j1hin3-6
a=media-release-con-addr:d6v1k1hvmgvh1002o9j0
m=audio 18648 RTP/AVP 8 0 18 96 97
b=RR:3000
b=RS:1000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:96 AMR/8000
a=fmtp:96 mode-set=7;max-red=0
a=fmtp:97 0-15
a=maxptime:40
2761956: May 13 00:43:51.745 AEST: //-1/C74262E7B81B/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=416961513
----- ccCallInfo IE subfields -----
cisco-ani=416961513
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=394564564
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
2761957: May 13 00:43:51.745 AEST: //-1/C74262E7B81B/CCAPI/cc_api_call_setup_ind_common:
Interface=0x23BEC850, Call Info(
Calling Number=416961513,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=394564564(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2000, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=7711303
2761958: May 13 00:43:51.745 AEST: //-1/C74262E7B81B/CCAPI/ccCheckClipClir:
In: Calling Number=416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2761959: May 13 00:43:51.745 AEST: //-1/C74262E7B81B/CCAPI/ccCheckClipClir:
Out: Calling Number=416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2761960: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761961: May 13 00:43:51.745 AEST: :cc_get_feature_vsa malloc success
2761962: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761963: May 13 00:43:51.745 AEST: cc_get_feature_vsa count is 1
2761964: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761965: May 13 00:43:51.745 AEST: :FEATURE_VSA attributes are: feature_name:0,feature_time:578028888,feature_id:560608
2761966: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=394564564(TON=Unknown, NPI=Unknown))
2761967: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_process_call_setup_ind:
Event=0x285A1280
2761968: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 394564564
2761969: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCallSetContext:
Context=0x943458C
2761970: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 7711303 with tag 2000 to app "_ManagedAppProcess_Default"
2761971: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCallProceeding:
2761972: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=99, Params=0x942C5B0, Progress Indication=NULL(0)
2761973: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCheckClipClir:
In: Calling Number=00416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2761974: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCheckClipClir:
Out: Calling Number=00416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2761975: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCallSetupRequest:
Destination Pattern=+61394564564, Called Number=+61394564564, Digit Strip=FALSE
2761976: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccCallSetupRequest:
Calling Number=00416961513(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+61394564564(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=416961513, Final Destination Flag=TRUE,
Guid=C74262E7-1786-11E6-B81B-E16E99A8BD08, Outgoing Dial-peer=99
2761977: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=00416961513
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+61394564564
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
2761978: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x23BEC850, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=00416961513,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+61394564564(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=99, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
2761979: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761980: May 13 00:43:51.745 AEST: :cc_get_feature_vsa malloc success
2761981: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761982: May 13 00:43:51.745 AEST: cc_get_feature_vsa count is 2
2761983: May 13 00:43:51.745 AEST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2761984: May 13 00:43:51.745 AEST: :FEATURE_VSA attributes are: feature_name:0,feature_time:578033368,feature_id:560609
2761985: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_api_event_indication:
Event=101, Call Id=7711303
2761986: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
2761987: May 13 00:43:51.745 AEST: //7711304/C74262E7B81B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
2761988: May 13 00:43:51.745 AEST: //7711304/C74262E7B81B/CCAPI/ccCallSetContext:
Context=0x942C564
2761989: May 13 00:43:51.745 AEST: //7711303/C74262E7B81B/CCAPI/ccSaveDialpeerTag:
2761990: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/ccGetMediaClassTag:
media class tag 0
2761991: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
2761992: May 13 00:43:51.747 AEST: //7711303/C74262E7B81B/CCAPI/ccGetMediaClassTag:
media class tag 0
2761993: May 13 00:43:51.747 AEST: //7711303/C74262E7B81B/CCAPI/ccSetMediaclassIp2ipTags:
2761994: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
2761995: May 13 00:43:51.747 AEST: //7711303/C74262E7B81B/CCAPI/ccGet_xc_nr_asp_info:
2761996: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/cc_api_event_indication:
Event=193, Call Id=7711304
2761997: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/cc_api_event_indication:
2761998: May 13 00:43:51.747 AEST: //7711303/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2761999: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762000: May 13 00:43:51.747 AEST: //7711304/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762001: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762002: May 13 00:43:51.747 AEST: //7711303/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762003: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762004: May 13 00:43:51.747 AEST: //7711303/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762005: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762006: May 13 00:43:51.747 AEST: //7711304/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762007: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762008: May 13 00:43:51.747 AEST: //7711303/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762009: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762010: May 13 00:43:51.747 AEST: //7711304/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762011: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762012: May 13 00:43:51.747 AEST: //7711304/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2762013: May 13 00:43:51.747 AEST: cc_api_get_xcode_stream : 4935
2762014: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/CCAPI/cc_api_call_proceeding:
Interface=0x23BEC850, Progress Indication=NULL(0)
2762015: May 13 00:43:51.747 AEST: //7711303/C74262E7B81B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 May 2016 14:43:51 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.3.3.M2
Content-Length: 0
2762016: May 13 00:43:51.747 AEST: //7711304/C74262E7B81B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+61394564564@172.16.81.75:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1.16:5060;branch=z9hG4bK1C167EE02
From: <sip:00416961513@acme.company>;tag=998B2938-23A8
To: <sip:+61394564564@172.16.81.75>
Call-ID: C742B193-178611E6-B821E16E-99A8BD08@10.1.1.16
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3343016679-0394662374-3088834926-2577972488
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1463064231
Contact: <sip:00416961513@10.1.1.16:5060>
Expires: 300
Max-Forwards: 28
P-Asserted-Identity: <sip:00412312312@10.1.1.16>
Content-Disposition: session;handling=required
Content-Length: 315
v=0
o=CiscoSystemsSIP-GW-UserAgent 3333 9888 IN IP4 10.1.1.16
s=SIP Call
c=IN IP4 10.1.1.16
t=0 0
m=audio 16986 RTP/AVP 8 0 18 97
c=IN IP4 10.1.1.16
a=fmtp:18 annexb=no
a=fmtp:97 0-15
a=ptime:20
2762017: May 13 00:43:51.753 AEST: //7711304/C74262E7B81B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.1.1.16:5060;branch=z9hG4bK1C167EE02
From: <sip:00412312312@acme.company>;tag=998B2938-23A8
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Murali Gunnam
CUBE has the capability of inter working between different dynamic payload types. Kindly find the below url for more explanation on this.
Command Reference:
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_a1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1618440
Since you already configured "asymmetric payload full", it should work. Kindly share the logs of below debugs and share for a test call along with calling , called number and DTMF digits pressed.
Krish
debug ccsip messages
debug voip rtp session named-event
