Cube Configuration
Josefine Mages
Hello :)
i have configuration my first Cube, but the outgoing calls doesn´t works.
The Error Code ist 403 Forbidden. Authentication failed on Invite.
I hope you can help me.
It is a 4321 ISR with the IOS isr4300-universalk9.16.03.05.SPA.bin
9 Replies 9
Are you getting 403 because of wrong authentication or may be your source
IP isn't trusted by provider.
If because of authentication, did you apply authentication and registration
commands under sip-ua
Vodafone say in my PAI Header we send a name. But how can i edit the header from name to number?
Best regards,
Josefine
Thank you for this Information, but my Provider say now, that i need for all my Numbers i need a sip trunk, to registration?
The test Number is registered over the sip trunk to Vodafone, but my other two pilot numbers not?
I´m confused. Can you help me?
Best regards,
You can use CUBE multi tenant feature to achieve this.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-multi-tenants.html#concept_D815178B3D964C8DA2CF89BABA04A50E
Balram
Please rate if you find this helpful
Thank You
Balram
That would be relevant if there is multi-tenancy i.e. multiple ITSP's. I believe the OP has Vodafone as the only ITSP.
Thanks all, for help.
sip-ua, i have configure, but the trunk don´t registered with vdf. The Error Message is 403 Forbidden.
Authentication failed on Invite or Authentication failed on Register.
Can you add the sip-ua config here or a show run from CUBE ?
