Incoming calls need to block
virendra pathak
Hello Team,
In one of the location, there is 2000 ext andon this ext user is getting unwanted calls so need to block the same for ext 2000.
Is it possible to block the incoming number ?
The prompt response would be highly appreciated.
Viru
Read through this.
https://supportforums.cisco.com/t5/other-collaboration-voice-and/block-incoming-call-with-voice-translation-rule/td-p/299925
Balram
Please rate if you find this helpful
Thank You
Balram
R0g22
Taken the fact that if you are using MGCP, then you need to do this on CUCM through TP. For H.323 or SIP, you can do it either on CUCM or gateway. On the gateway, the link shared by Balram will be helpful. You can review the following as well -
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
