12-28-2017 12:30 PM - edited 03-17-2019 11:51 AM
12-28-2017 05:03 PM
If I understand you correctly, you’re saying that CUBE receives a mid-dialog reINVITE from one side and instead of sending it within the existing dialog on the other side it creates a new one? IF true that would be a defect because CUBE should recognize the existing dialog state based on the Call-ID headers. Can you share a properly redacted config (ie no passwords) and the output of ‘debug ccsip messages’ showing an example of this? Please note the calling/called numbers and what the IPv4 addresses involved in the debug are. Also what equipment and IOS version?
12-28-2017 06:27 PM
12-29-2017 04:07 AM
Just to add to what Jonathan and Mohammed have both said. CUBE will send RE-INVITE to the contact header in the dialog, since RE-INVITE is a future request. Now for your call to have been successfully completed then the contact header is correct because your ACK is also sent to the contact header. To understand what is going on fully, we will need your logs as requested. We need to see debug ccsip messages from CUBE.
