05-14-2020 12:39 PM
I'm trying to deployley CUBE HA with multiple services provider connection using with IS4K cube but Im confusing some point for this deployment.
Normaly I should use redundancy group instead of HSRP but I can not understand how can I do that for multiple trunk on WAN side.
I can see that figure 4 there could be possible for multiple itsp connection on ISR4k
I need a help for cube ha deploymeny with multiple itsp connection with isr4k router but i think this could be resundancy group desiginnbut i can not understand how can i do that can you please find me example config or template if you can someone share their experince i will be very happy.
Solved! Go to Solution.
06-20-2020 01:02 AM
Great answer Ritesh. (+5)
06-20-2020 09:41 AM
@Roger Kallberg thanks.
I have just published the article on gathering the SIP trunk pre-requisites from SIP Service Provider. Check here
