IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5861 Views
  • 14 replies
Hello Team,I have Cisco 4351 router with NIM-4FXO and 4FXS card..I have required to terminate 4 PSTN line on these cards..I am confused between how incoming and outgoing will work.How DID will work, and should I configure the gateway as MGCP or H.323...
My Voicemail button is not showing in my Windows Jabber Client.  We are running BE6K with CUCM,CUC,CUPS 9.1.  The only walkthroughs I have seen for this are for older versions of CUCM and I don't have the same options.Thanks for all of your help     ...
Hi, We have SSO enabled on UC environment (CUCM,CUC,Jabber) recently we had SSO outage. During login to each service we got message. Invalid Status code in response. This may be caused by configuration error in the IDP.We also have SSO on Webex but W...
mistemarc by Level 1
  • 1142 Views
  • 1 replies
Our customer is looking to have different display name for both internal and external calls.Like if it's internal call then person's name should be there but when someone make a call outside it should display company's name.I have tried different wor...
Resolved! C3925-CME-SRST/K9
Hi Guys, Can I check can I use C3925-CME-SRST/K9 model to support 700 users for the voice? As currently we only support 200 users and we are moving into new building or should we replace it with a new model?
ciscoguy88 by Level 1
  • 1382 Views
  • 12 replies
Hello, We have CUCM 9.1 with MGCP gateways + ISDN trunks, I'm looking for a solution for correct displaying of calling party in forwarded calls ... At present, when an incoming PSTN call is forwarded, what is displayed at the destination is our root ...
