CUBE - IOS 15.1(3)T Media Flow Around command
Felix Sarayar
I can only manage to configure the media flow around command under a dial-peer.
Router(config-dial-peer)#media ?
  flow-around   The media is to flow around the gateway
  flow-through  The media is to flow through the gateway
  forking       Enable media forking
I wish to configure this command under Voice Service Voip
Router(conf-voi-serv)#media ?
  anti-trombone  Media Anti-trombone
  transcoder     Media transcoding functionality
Do I just have to enable it under each dial-peer then?
I have enabled 'mode  border element' and reloaded.
Felix
Harmit Singh
Hi Felix,
In Cisco IOS Release 15.1(3)T, support for the  Configured Delayed-Offer to Early-Offer Media Flow-Around feature at the  global and dial-peer level was introduced.
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip.html#wp1392896
Looks like you forgot to add "allow-connections sip to sip" under voice service voip. Once you add this, you should have the option to configure this globally.
HTH.
Harmit.
Harmit Singh
Hi Felix,
HTH.
Harmit.
Thanks Harmit!
