Hi All,
I have a setup where the default gateway for the subnet is also acting as a voice gateway (CUBE on ISR 4321).
My question, If i add another router (Maybe a cheap 1100 series) configured only with HSRP and add a loopback interface on the ISR 4321 will it work?
(I dont want CUBE-HA). i just want to address the limitation of the default gateway.
I'm thinking i probably will have to bind the dial-peers on the ISR to use the loopback, thoughts..??
Hope this makes sense, and let me know if you need any additional details.
thanks,
Kevin
