CUBE - send SIP signaling down a different path
dshumake
Level 4
Level 4
Hello All,
First this is what I am trying to do.
int: 0/0/0   inbound from ATT
int: 0/0/1   outbound to avaya
int: 0/0/2   outbound to proxy server
incoming call
   signaling path:   att --> cube --> proxy server --> cube -->  avaya (agent)
    media path:       att --> cube -->  avaya (agent)
Does any have an example on how to build the voice dialpeers for this going to proxy servers and avaya?
9 Replies 9
Steven L
sip bind commands is what you need.
bind control source-interface int 0/0/2
bind media source-interface int 0/0/1
that being said, i dont follow the cube>proxy>cube>avaya flow.
Are these 2 different cube routers?
forgot to add,  this is one router
ok...i believe i answered your original question. so unless it is not working, i am not sure i NEED to understand what you are doing with the bounce off the proxy back to the CUBE.
Are you still having an issue?
dshumake
Level 4
Level 4
avaya flow mean connecting to Avaya ASM
I think what Steve meant is that you have 2 SBCs (Cubes) mentioned in your outline of the call path.
“signaling path: att --> cube --> proxy server --> cube -->  avaya (agent)”
Response Signature
yes. that is correct.
@Roger Kallberg  What I understood is , he is asking if he can bind the media through one port and signalling through another port which go through a  proxy.
@dshumake Not sure why you need to do this. But  I think   this will make things more complicated.
Response Signature
I understood the path @Nithin Eluvathingal, it was @Steven L that asked about the second SBC in the described path.
Response Signature
dshumake
Level 4
Level 4
this is one cube...
with be routing the signaling traffic to a proxy (3rd party device/ application) then flow back to cube on the call center agent on Avaya.
with is a special app to monitor calls  if that make sense.
