CUBE: SIP<->H.323. No DTMF in H.323
pavelsh_ucs
We have CUBE configuration SIP <-> H.323 (CUCM 8.6)
Calls are delivered as follows:
IPTSP<--sip-->CUBE<--h.323-->CUCM<-->phone
When I'm calling from inside to outside (From the phone to PSTN by IPTSP) DTMF is working just fine.
But when I'm calling from outside to inside (From PSTN to the phone) DTMF isn't working. I see that the CUBE recognise DTMF on SIP leg, but don't send DTMF through H.323 leg
The CUBE is on ios version 15.1(4)M6.
A config is attached below.
Chris Deren
None of your H323 dial-peers are defined as inbound dial-peers and only your dial-peer 505 and 205 have incoming-called number with specific number defined.  You need to remember that every call in voip world has 2 call legs, in your case there is an incoming call leg from IPTSP via SIP and outbound H323 to CUCM, both need to be matched, first with incoming called-number and second destination-pattern in most cases.
What I would suggest would be to standardize on single protocol (SIP) to make it easy on yourself.
HTH,
Chris
Hi Chris,
Why do you think that I don't have an incoming dial-peer for h.323?
1. The 205 is incoming dial-peer for h.323 from my point of view and from Cisco ios point of view (it is matched correctly)
2. Call h.323 -> sip is working just fine. So incoming h.323 dial-peer is fine
Incoming sip dial-peer is working good too.
Chris is right
If you want your setup to work properly then do all the ways with sip.Sip trunk with  ISP and Sip trunk to CUCM
Then you have to create 4 dial peers.Two  dial peers pointed to cucms  , one pointed to sip trunk for outgoing and one pointed to sip trunk for incoming.The  incoming dial peer will be used also from CUCMs....
Dont use specific number in the incoming dial peer.Just use << incoming called-number . >>
I have simmilar issues with your setup and when i used ONLY SIP then everything worked perfect
Please rate all useful posts
Chrysostomos
""Thinking is the hardest work there is , which is probably the reason why so few engage in it""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Tapan Dutt
I haven't taken a look at the show run yet but try invoking IOS based MTP from CUBE.
Tapan
