CUBE - SIP SIP/2.0 400 Bad Request
ciscoMFNAO
Hi All,
We are configuring our new SIP Trunk to a Provider. Everything is configure and external calls were working fine but at some point external calls are getting fast busy and only incoming calls are working.
                          Topology: CUCM-SIP Trunk-CUBE-Sip Trunk - ISTP
                          Call test: Calling-9521(mask 222679500) Called 0917775245 (0 is striped)
Any ideas what can be causing it...
Please note attached collected debugs calls from  and show runs.
2 Accepted Solutions
Dennis Mink
Hook up with your provider, they are not liking your invite, seeing it has always worked and now it doesnt tells me something has changed on their end.they should be able to tell you want is wrong about your invite
Please remember to rate useful posts, by clicking on the stars below.
R0g22
Nothing that strikes out from the invite that CUBE is sending. I am assuming that your firewall/nat device is NAT'ing correctly. Why not take a pcap from the egress edge firewall to see and then send them across to your itsp! If they still not agree, escalate it at their end. You would need to push things towards them. Have them involve their Tier 3 guys. They usually know what is going on.
7 Replies 7
Dennis Mink
Hi Dennis, Thanks for your replay.
I just got in contact with the Provider and they insist they didn't changed anything from their side and saying they´re not able anything coming from our side when call is placed.
Very strange.
Any ideas....?
Thanks so much for your support.
They managed to get it working. I don´t know what they did but calls are working fine now without any action from my side.
Cheers,
R0g22
You´re Nipun.
I put some pressure and they managed to get it working. I don´t know what they did but calls are working fine now without any action from my side.
Thanks for your support,
You need to do that when dealing with ISP's. Good that your issue is resolved. :)
good work mate. I my 20 years of IT experience: if something breaks it most likely because some one changed something,
