CUBE (SIP trunking) on 3725
kardos420
Is CUBE supported on the 3725 platforma and if so, what part numbers are required to upgrade the router to support it?  Parts like CUBE licensing, PVDM's and needed DRAM/Flash.
David Smith
Yup, CUBE is supported on the 3725 platform, see below:
http://www.cisco.com/en/US/customer/docs/ios/voice/cube/configuration/guide/vb-gw-overview_ps5640_TSD_Products_Configuration_Guide_Chapter.html
You'd need to load the "adventerprisek9_ivs-mz" or "ipvoice_ivs-mz" feature set, per the above doc, for CUBE functionality.  The IOS for 3725 is limited, latest is 12.4(15)T14. 12.4(24)T and 15X images are not available for this platform, so only basic CUBE features and supplementary services are available on the 3725...you wouldn't have access to the more recent/advanced CUBE features and supplementary services.
No licenses are needed, only the "voice service voip" configs such as:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
This enables IP-IP GW/CUBE functionality.
No, PVDM's aren't needed, not unless you plan on configuring locally registered transcoding/MTP.  But not needed for basic CUBE functionality.
The DRAM and flash requirements, as well as IOS feature sets are listed below:
INT VOICE/VIDEO, IPIP GW, TDMIP GW
c3725-ipvoice_ivs-mz.124-15.T14.bin
Release Date: 20/AUG/2010
Size: 33581.43 KB (34387384 bytes)
Minimum Memory: DRAM:256MB   Flash:64MB
INT VOICE/VIDEO, IPIPGW, TDMIP GW AES
c3725-adventerprisek9_ivs-mz.124-15.T14.bin
Size: 45752.79 KB (46850852 bytes)
Basic CUBE configuration guide:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-config.html
Hope that helps
