02-13-2018 06:21 AM - edited 03-17-2019 12:11 PM
Hi guys, if SIP Carrier provided plan to install 3 sip trunk to 1 site where I have 1 CUBE and CUCM , does this mean that I will just have 3 different dial-peers with 3 different IPs of Carrier ?
If yes, how can I separate those dial-peers ?
thank you
Solved! Go to Solution.
02-16-2018 01:32 PM
02-13-2018 06:33 AM
02-13-2018 06:36 AM
what about my first question is it true or not ?
02-13-2018 06:37 AM
02-13-2018 06:50 AM
I think i don't need multi-tenant configuration because we will use those 3 sip trunks for 1 company only. Is this correct ?
1 sip tg is active as backup go to backup switches of the Carrier, so if I create dial-peer 9 for active, then 92 and 93 for backup with different IPs it should work. Right ?
02-13-2018 06:56 AM
02-13-2018 07:15 AM
Looks at this document:
They programmed 2 sip trunks by using different dial-peers BUT not multi-tenant feature .
So I think I can do same thing with 3 sip trunks.
02-13-2018 10:05 AM
02-16-2018 01:27 PM
ITSP doesn't require registration or proxy auth. So I can have 3 dialpeers with 3 IP of ITSP or voice class server group .
Thank you
02-16-2018 01:32 PM
02-13-2018 08:04 AM
First question would be why would you need 3 separate SIP trunk from the same carrier at the same location?
02-13-2018 10:01 AM
we connect to 1 sip carrier, kinda their cloud, they have 3 or 4 switches in LA, NY, somewhere else , and they proposed this plan for redundancy. So I was thinking if i set up 3 dial-peers with diff preferences and diff carrier ip's then that will be considered as 3 sip trunks .
Never had experience with multipple sip trunks on 1 cube, so i was confused a little bit when i saw their proposal and trying to figure it out myself.
02-13-2018 10:06 AM
So, one SIP trunk with multiple SBCs.
The easiest way to handle it assuming you are on IOS version supporting this feature is to use
"voice class server-group" feature where you can define all of the destinations and apply to one dial-peer, alternatively you can use the old school method with 3 dial-peers with different preferences.
02-13-2018 10:41 AM
no, 1 cube and 3 sip trunks to the same sip carrier .
