07-04-2018 08:03 AM - edited 03-17-2019 01:08 PM
09-09-2018 06:17 AM
09-09-2018 06:23 AM
i added the
bind control
bind media
on the sip configuration
it doesn't resolve the issue
07-09-2018 06:15 PM
Also what is the topology?
Any firewalls in the way?
07-16-2018 06:40 AM
07-26-2018 11:52 PM
Your trace only shows SIP INVITEs destined for 10.10.31.94 with no responses.
Not sure of your topology but i would do another trace from the "internal" interface of CUBE to see what is happening .
Also do a debug ccsip message, debu voip dialpeer all (take usual care if prod system whilst running any debugs) and pump another call thru and show dial-peer voice summary and show us more of the config as there may be translations etc happening . Hard to help without all the info as we cannot even rule out an IP routing issue at the moment .
07-29-2018 06:58 AM
07-29-2018 04:31 PM
debugs would be required. Quick look at your config and referencing with with Wireshark trace's incoming SIP INVITE, at least your dial peers are an issue.
08-26-2018 01:34 AM
09-07-2018 08:57 AM
I still don't see the carrier IP in the trust list, I also don't see an inbound dial peer for the carrier.
Unless I am missing something here.
09-07-2018 10:20 AM
