images not transfer to background on ip phone 7945
amralrazzaz
Level 5
Level 5
hi all
i extract some images via tftp server to flash of router and add images.png to tftp server
then reset ephone (7945) but still not appear on backgrouds option
please find attached file of show flash and also this is what i did :
archive tar /xtract tftp://192.168.2.120/320x212x12.tar flash:
281 0 Jun 3 2018 14:23:22 +02:00 flash
282 0 Jun 3 2018 14:23:22 +02:00 flash/cmterm-78xx.12-1-1-12
283 0 Sep 5 2018 11:00:42 +02:00 320x212x12
284 0 Sep 5 2018 11:00:42 +02:00 320x212x12/320x212x12
285 131470 Sep 5 2018 11:00:42 +02:00 320x212x12/320x212x12/CampusNight.png
286 80565 Sep 5 2018 11:00:44 +02:00 320x212x12/320x212x12/CiscoFountain.pn g
287 138278 Sep 5 2018 11:00:46 +02:00 320x212x12/320x212x12/Fountain.png
288 135184 Sep 5 2018 11:00:48 +02:00 320x212x12/320x212x12/Frico.png
289 730 Sep 5 2018 11:00:48 +02:00 320x212x12/320x212x12/List.xml
290 109076 Sep 5 2018 11:00:50 +02:00 320x212x12/320x212x12/MorroRock.png
291 108087 Sep 5 2018 11:00:50 +02:00 320x212x12/320x212x12/NantucketFlowers .png
292 10820 Sep 5 2018 11:00:52 +02:00 320x212x12/320x212x12/TN-CampusNight.p ng
293 9657 Sep 5 2018 11:00:52 +02:00 320x212x12/320x212x12/TN-CiscoFountain .png
294 7953 Sep 5 2018 11:00:52 +02:00 320x212x12/320x212x12/TN-Fountain.png
295 7274 Sep 5 2018 11:00:54 +02:00 320x212x12/320x212x12/TN-MorroRock.png
296 9933 Sep 5 2018 11:00:54 +02:00 320x212x12/320x212x12/TN-NantucketFlow ers.png
tftp-server flash:320x212x12/320x212x12/CampusNight.png
tftp-server flash:320x212x12/320x212x12/CiscoFountain.png
tftp-server flash:320x212x12/320x212x12/Fountain.png
tftp-server flash:320x212x12/320x212x12/Frico.png
tftp-server flash:320x212x12/320x212x12/List.xml
tftp-server flash:320x212x12/320x212x12/MorroRock.png
tftp-server flash:320x212x12/320x212x12/NantucketFlowers.png
tftp-server flash:320x212x12/320x212x12/TN-CampusNight.png
tftp-server flash:320x212x12/320x212x12/TN-CiscoFountain.png
tftp-server flash:320x212x12/320x212x12/TN-Fountain.png
tftp-server flash:320x212x12/320x212x12/TN-MorroRock.png
tftp-server flash:320x212x12/320x212x12/TN-NantucketFlowers.png
after that i reset ephone to check but no luck  could you please help
i have something strange i have 2 kind of phones but i can see only framware of only cp 7821 but i cant see the framware of 7945 ? is it  okay
 here ypu are also the phones configurations :
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.2.207 port 2000
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 25
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name ...... password .....
web admin customer name ..... password ......
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Sep 04 2018 13:06:27
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone-dn 2 dual-line
number 117 no-reg primary
label 117
description Walid Hifny
name Walid Hifny
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
video
mac-address 7001.B5DD.E0FC
username "walid"
paging-dn 2
type 7945
button 1:2
pin 4100
ephone 5
amr alrazzaz
2 Accepted Solutions
What do you see on the phone ? Enable "debug tftp events" and go into Background Image setting on the phone to trigger the TFTP request. Post the output here.
Remove the alias keyword from the TFTP bindings. The directory being requested is correctly configured on the flash. Test again after that.
Currently, the phone is requesting the XML but the CME is not able to provide it or find it correctly.
17 Replies 17
Leonardo Santana
Check the paths to of the images if they are correct. Other thing to check is the format of the images.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/69187-cme-cust-img-7970.html
Only the 7945 are not loading the background image?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
is there any command should i apply under telephony-service ?
to apply the transferred images to phone after reseting phone ?
should i recreate files?
amr alrazzaz
Try to recreate the cnf-files and reset the IP Phones.
Leonardo Santana
same doesnot transferred
so should i load files under telephony-service to apply on ephone ?
amr alrazzaz
Config files are NOT used for background images. They are not related at all.
can i use this
telephony-service
 load 7945 Frico       (or this command for firmwares only ?) not for files like file.png for example
exit
tftp-server flash:Desktops/320x212x12/Frico.png
amr alrazzaz
If you are trying to change the background image on the phone, all you need to worry about is the "List.xml". The XML needs to reference the thumbnail and the main image. All these files need to be in the flash. Also remember the images need to have the correct resolution and the color depth. If the color depth is incorrect, you would just get a blue screen.
Use this for the resolution -
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/9_0/english/admin_guide/P747_BK_W06BD6D9_00_adminguide_7945-7965-7970-7971-7975/P747_BK_W06BD6D9_00_adminguide_7945-7965-7970-7971-7975_chapter_0110.html
please check list.xml attached
amr alrazzaz
Looks correct to me. Ensure that the thumbnail and images are in the same directory as in the List.xml. If not, then you would need to create alias to fix that.
"tftp-server flash:Desktops/320x212x12/Frico.png" >> this is called a TFTP binding. Ensure this is present for all images that you need on the phone and the List.xml as well.
Take a "debug tftp events" while you navigate to the images section on the phone and see if what is the phone requesting and if CME is able to provide it or not.
I will put emphasis again on the importance of correct resolution for background images to work correctly.
just to ask there is no any command to do under telephony-service ???
coz i have another type of phone 7821 and there is load option under global voice register to upload the files to phone
just need clarifications
thanks alot
amr alrazzaz
Load command is to populate the firmware in the config file when you do a create profile or create cnf. Background images rely on List.xml and not the config file xml.
okay boss how i load the images to 7945 phones background after the following
tftp-server flash:Desktops/320x212x12/TN-Fountain.png alias TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png alias TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/MorroRock.png alias MorroRock.png
tftp-server flash:Desktops/320x212x12/List.xml alias List.xml
tftp-server flash:Desktops/320x212x12/Frico.png alias Frico.png
i already recreate cnf-files under telephony-service and reset ephones but still not send to phones
thanks alot man
amr alrazzaz
Router#debug tftp events
TFTP Event debugging is on
please check the attach pic of what i saw on background setting of Cisco phone
nothing appears
amr alrazzaz
